09-29-2008 10:31 PM - edited 03-03-2019 11:44 PM
I have a mesh network and direct Internet access comming from my ISP using dot1q vlans over an ethernet interface. I have an internal interface and a DMZ interface(for the Direct Internet Access). How can I prevent the DIA interface from talking to the inside lan interface. Bacically I want to seprate the two networks respectively. Is there a way to prevent one interface from talking to another?
interface GigabitEthernet0/0
description LAN_Inside
ip address 10.10.0.4
interface GigabitEthernet0/1
description LAN_DMZ
ip address <public_IP> 255.255.255.192
interface FastEthernet0/0/0
description ISP_10meg_port
no ip address
service-policy output voip
interface FastEthernet0/0/0.1512
description ISP_MESH_to_LAN_Inside
encapsulation dot1q 1512
ip address <CPE_Mesh_WAN_IP> 255.255.255.252
interface FastEthernet0/0/0.1513
description ISP_DIA_to_LAN_DMZ
encapsulation dot1q 1513
ip address <CPE_DIA_WAN_IP> 255.255.255.252
router bgp 1234
network 10.25.0.0 mask 255.255.255.0
neighbor <PE_Mesh_WAN_IP> remote-as 5678
ip route 10.25.0.0 255.255.255.0 10.6.0.3
09-30-2008 03:09 AM
Tom
I think that VRF lite would be a feature that would provide the isolation that you need.
Rick
09-30-2008 08:43 AM
Here is my start at a VRF config. Will this effect my dot1q vlans, or anything other than these interfaces? Anything I'm missing? Thanks.
ip vrf DIA
rd 1:1
ip vrf Mesh
rd 2:2
ip vrf forwarding Mesh
description LAN_DMZ
ip address
ip vrf forwarding DIA
no ip address
ip address
ip address
router bgp 1234 vrf MESH
neighbor
ip route vrf mesh 10.25.0.0 255.255.255.0 10.10.0.4
ip route vrf DIA 0.0.0.0 0.0.0.0
09-30-2008 02:58 PM
I should have added this is a 3845 router.
09-30-2008 06:10 PM
Tom
I do not believe that there is an issue to do VRF lite on 3845. I do not believe that it will affect your dot1q VLANs.
Rick
10-01-2008 02:32 PM
I'm also looking at using Zone-Based Policy Firewall (ZFW). This seems to also solve my problems. I don't have overlapping routing so I don't think I need VRF for that purpose. If I just need to isolate the interfaces into two secutity zones then ZFW seems to work well. Does anybody know if ZFW is a good solution? Thanks--
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00808bc994.shtml
