Webcast-Catalyst9k
ISP DHCP to Static ip.
I have problems with PAT translation to a inside server. Somebody tell my that i can`t use a dynamic DHCP of the ISP to use the NAT/PAT transalation. If i configure a static ip-adres on the BVI interface then en can`t ping the ISP gateway. Is it possible to configure this a staic ip with ISP DHCP? Is is possible to use Dynamic ip for NAT/PAT?
I hope somebody can helping.
Bart
Config:http://www.pc-check.nl/config.txt
Silver
Re: ISP DHCP to Static ip.
I think you can use dynamic IP for Port Address Translation. For this you have to use command "set ip pat porthandler". Following link may help you
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/750/700cr44//700crip.htm#xtocid554923
Hall of Fame Super Gold
please configure:
int eth0
no hold-queue 100 out
int atm0
no bridge group 1
no pvc 0/34
int atm0.1 point-to-point
bridge-group 1
pvc 0/34
encapsulation aal5snap
int bvi1
no ip access-list 100 in
no ip route 0.0.0.0 0.0.0.0 84.107.216.1
That should make things work.
I'm astonished about the other answer about an old series 700 non-ios router, now dead since almost 10 yers!!!
Hope this help. Please rate all useful posts using the scrollbox below!
Thanks for the answher. You can use dynamic ip-adres with NAT translation. I do wrong check. If i check is everything work of the inside network (Does work). If i make a vpn en check the static nat from extern it work fine. Thanks for the tips maby i can use in the feature.
198
