04-28-2008 05:07 AM - edited 03-03-2019 09:43 PM
How to whitelist IP's if the service provider is Blacklisted, the result of this is undeliverable mails as they are getting bounced back. While some specify the reason, others say PTR records missing. Pls suggest
Thanks in Advance
05-09-2008 11:00 AM
You must work with your provider in some cases.
Other cases simply require a reverse-lookup in your dns.
please see the following links for more info on dns reverse-lookups:
reverse lookup tool -
http://www.zoneedit.com/lookup.html or
description - http://support.microsoft.com/kb/164213
10-09-2008 03:44 AM
HI Satya,
The IP's can be whitelisted unless & until the ISP pay to the Blacklisting authority and control the No# of SPAM Messages.
The Temporary workaroud is, if the ISP has a RELAY Service means kindly avail the same. This might solve your problem of Mailing issues.
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
