10-09-2010 07:50 AM - edited 03-04-2019 10:02 AM
What's the maximum of route entry capacity of the ISR G2(1941,2921,3925)?
I couldn't find any reference to the info..
It's depend on the memory..?
Is there any docs to this? links?
Tomoyuki
Solved! Go to Solution.
10-10-2010 08:17 AM
For OSPF the memory usage depends on the topology, type of routes and size of LSA's. Genernally speaking you can average 300-400 bytes per route (again this really depends on a number of factors. Worst case would be around 500 bytes, so 500*35,000 would be 17mb's.
Tim
10-09-2010 09:07 AM
Why do you worry? How many routes do you need ?
10-09-2010 02:54 PM
There are 3500 routes we need.
Our customer is asking for warrant of the stability proof.
Thanks.
Tomoyuki
10-09-2010 03:08 PM
The only limitation to the amount of routes is processor memory. Each route, depending on the routing protocol will consume x amount of processor memory until it is exhausted. To be completely honest, 3,500 routes is nothing compared to what a lot of other customers are doing
Which routing protocol are you planning on running?
Tim
10-10-2010 06:15 AM
hello tim,
Thanks for your reply.
I'm planning on OSPF on the each router.
Do you think it'll work without problems?
Tomoyuki
10-10-2010 06:23 AM
t-yamashita wrote:
hello tim,
Tomoyuki
15 years ago, I was using 35,000 routes without any problem, on 2500 routers with 16 MB of memory.
3,500 for a router of today is really nothing, as Tim remarked above.
10-10-2010 08:17 AM
Tim
10-10-2010 03:12 PM
Thank you for your helpful answer.
Tomoyuki
