Community Member
Issue with a Cisco 2821-HSEC/K9
Hello Folks!!
I have adquired a Cisco 2821 Security Bundle. I have conected a desktop computer with a straight-throught wire and I can see as the Lan Network fail intermittently. I have tested it with a cross-over wire and with other desktop and the problem is the same. The lan interface is disconnected and connected again intermittently.
Is possible that the interface GE0/0 is damaged.
Thanks in advance!!.
Hall of Fame Super Gold
Re: Issue with a Cisco 2821-HSEC/K9
Very unlikely, try hardcoding duplex and speed.
Community Member
Hi, Thanks by your response. I can see that the SYS PWR led is blinking, then it stops for a moment and the led's light is switched on, then it switch off and it starts again the same process.
I think that the problem is the proper device and not the network.
Have you connected to the router via serial console for initial configuration ?
If you have not done that, whatever the LAN port does, is irrelevant.
Community Member
The console via serial show nothing!!.
Community Member
One moment...!, I have removed the Compact Flash and now it's working. The Compact Flash was inserted when I unpcked the product.
Community Member
Sorry, I had a mistake, it not works either.
Community Member
I have got to enter via serial. I can see the next error during the boot:
****** ERROR detected on PCI0 Bus
****** Try RESEATING all modules in the system
****** pci0_int_cause 0x00000200,
****** pci0_err_addr 0x00023801, pci0_err_cmd 0x0000000A
****** PCI Target Abort
Do what it's suggesting you, open it and reseat all modules.
If still trouble, return to vendor.
Community Member
Yes, I will do it.
Greetings!!, Thanks for help me.
You're welcome, please remember to rate useful posts with the scrollbox below.
437
