Issues with QoS on 1841 routers
Hi all,
I have run into what appears to be an issue with my QoS settings on some new 1841 routers. I used the same settings as our older 2600 & 3600 routers, but now it does not seem to work.
My router is a 1841 running IPBASE 12.4(1b). The WAN connection is a T1x2 using a multilink interface. After running tests pushing as much traffic as the link would handle, I ran a sh policy-map for this interface and the results look a bit strange for my VoIP class:
Class-map: VoIP (match-all)
38075 packets, 55940389 bytes
5 minute offered rate 916000 bps, drop rate 0 bps
Match: access-group 120
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 768 (kbps) Burst 19200 (Bytes)
(pkts matched/bytes matched) 2/3004
(total drops/bytes drops) 0/0
The matched queue packets don't match up with the number of class-map matched packets. Also instead of limiting the traffic to 768K it was able to reach 1.43M. A second instance of the test was pushing traffic on a non-priority IP range and took up the other 1.47M.
Here are some of the configs:
class-map match-all VoIP
match access-group 120
class-map match-all Vision
match access-group 121
policy-map CoS
class VoIP
priority 768
class Vision
bandwidth 384
class class-default
fair-queue
interface Multilink1
description T1 MLPPP Bundle
bandwidth 3088
ip address x.x.109.250 255.255.255.252
no ip route-cache cef
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
service-policy output CoS
interface Serial0/0/0
no ip address
encapsulation ppp
no fair-queue
service-module t1 timeslots 1-24
ppp multilink
interface Serial0/1/0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
I see similar stats from another new 1841 router. Class-map matched packets were over 19 million, but the queue stats for that policy-map only show 2 million matched packets.
On our older 36xx and 26xx routers running 12.2 seem to show that the claa-map matches and queue matches have the same number of matched packets when the link is under a heavy load.
Any ideas what I may have done wrong or missed?
Purple
Re: Issues with QoS on 1841 routers
HI Matt,
There is a subtle difference between the two counters that you should be aware of:
- the class-map counter counts all packets that were classified to that class-map
- the 'pkts matched; queue counter only shows the number of packets that were actually queued.
The difference is that, under non-congestion conditions, packets bypass the software queue altogether and are placed straight into the hardware tx-ring. Therefore, these packets do not count under the queue counter.
As you mentioned, under heavily loaded conditions, the counters match, because most packets are being software-queued.
So the behaviour you are seeing is quite correct.
Hope that helps - pls rate the post if it does.
Paresh
Hi Paresh,
When I was running the tests the network was under 95-100% load. The test site has 2 T1 circuits setup as a multilink bundle. During the test phase I was pushing out a total of 3Mb of traffic. Using Iperf I had two hosts sending TCP data as fast a they could out of the site with the 1841. One host was setup to match the "VoIP" ACL and another host was setup to match the default class.
Under full load I would expect two things.
1. Some of the data matching the "VoIP" ACL should have been queued.
2. Under full load the priority 768 limit should have capped the data sent through the "VoIP" queue.
What I saw was that the two hosts each were able to send through roughly the same amount of data. the pkts matched queue counter only recorded 2 packets being queued.
When I reverse this test and send data out from a site that has a 3660 running 12.2(16a) I get the expected results. Packets in the VoIP queue match the class-map and the host in the "VoIP" ACL is limited to 0.76 Mb throughput and the host in the default class is able to push through 1.87 Mb.
Matt
Purple
Hi Matt,
I see now what you are getting at...
Would you beable to post the output of the following at the time you are running the test:
- show policy-map interface multilink1
- show interface - for the interfaces which are pushing data in (from your two hosts).
Paresh
I'll need to run some more tests to get the output from the FastEth interface, but I do have a copy of the "show policy-map" from my earlier test. Counters were cleared shortly before the test was run, test lasted 5 minutes.
"sh policy-map interface multilink1 output" results
Multilink1
Service-policy output: CoS
Queueing
Strict Priority
Class-map: Vision (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 121
Queueing
Output Queue: Conversation 265
Bandwidth 384 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
(depth/total drops/no-buffer drops) 0/0/0
Class-map: class-default (match-any)
46287 packets, 58159363 bytes
5 minute offered rate 969000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
Matt
Purple
Hi Matt,
You might want to configure 'load-interval 30' on that interface to get more accurate stats...
The total traffic hitting the output interface is: 916000 + 969000 = 1885000, which is still less than 2*T1. That means that interface is not congested and your stats are correct. To observe congestion, you will need to offer traffic that is really well in excess of 3Mbps. Maybe 3.5 Mbps would be a good test...
Paresh
114
