KeepAlive on Serial Interface
Rupesh Kashyap
Hi, I want to change Keepalive timer on the interface like, If s0/0 is down, then it should send the down message only after 5 second. Please help.
Danilo Dy
1. To set it to default 10 seconds
keepalive
2. To set it to 5 seconds
keepalive 5
3. To disable keepalive
no keepalive
keepalive disable
Giuseppe Larosa
Hello Rupesh,
the interface will be declared down after missing three consecutive keealives so with default settings it is after 30 seconds
use
keepalive 2
to see if after 6 seconds
Hope to help
Giuseppe
Rupesh
Also be sure that the setting of keepalives is the same on both ends of the serial connection. If you set one end to keepalive 2 and leave the other end at the default of 10 you will find that the router with the short keepalives will flap which is caused by the mismatch in the keepalive timer.
Rick
Rick
