Webcast-Catalyst9k
Key Proc process
Hi all,
Just wondering if anybody had any information on 'hourly' spikes on CPU relating to the process Key Proc?
2561XM with 12.3.13 crypto code.
this probably has something to do with the crypto sa lifetime so I've changed that from 3600 (1hr) to 7200 (2hrs) to see what happens.
Ken
thanks in advance.
Ken
Re: Key Proc process
Ken,
From my experience, the "Key Proc" under "show proc cpu" is for Secure Shell Key Generation.
When you do a "show proc cpu", what are the values under 5Sec 1Min 5Min when you see the spike. Is there anyway, you could post the output of "show proc cpu".
I hope it helps.
Arul
Hi Arul,
details below,
116 10702042 53413 200367 62.47% 10.16% 2.18% 0 Key Proc
these %'s taper off for the following hour until they basically average out to 0% 0% 0% and again 1hour later the CPU spikes to ~90% Key Proc.
116 13956287 70072 199170 86.42% 11.49% 2.44% 0 Key Proc
Ken
281
