L2TP (LAC can't establish L2TP with LNS)
I am using cisco7200 as LAC and th following is configured in rouer:-
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
vpdn enable
vpdn-group 1
request-dialin
protocol l2tp
domain iwan
initiate-to ip <lo of the LNS>
source-ip <lo of LAC>
local name IWAN-FAH-TEST
l2tp tunnel password cisco
username cisco password cisco
interface Loopback0
ip address <lo of the LAC> 255.255.255.255
And ERX is used as LNS and following is the configuration:-
profile "Cust-LNS"
ip sa-validate
ppp authentication virtual-router default pap
pppoe sessions 1
profile "PPPOE-Profile"
ip unnumbered loopback 0
ppp authentication pap
pppoe remote-circuit-id
vlan auto-configure pppoe
profile "ppp-profile"
ip sa-validate
l2tp destination profile "Cust-LNS" virtual-router default ip address <LAC lo>
remote host "IWAN-FAH-TEST"
profile "Cust-LNS"
local ip address <LNS lo>
radius authentication server <RADIUS IP>
udp-port <port>
key <key>
radius accounting server <RADIUS IP>
udp-port <port>
key <key>
the issue now is the L2TP tunnel is not established and nother is coming from the debug!
If I need to establish this tunnel from fa0/0 in 7200 and ERX, is there is any thing need to be configured in interface?
If there is any think missing in the above configuration?
1 REPLY
Re: L2TP (LAC can't establish L2TP with LNS)
cant really tell what your exactly trying to do from the configuration but as far as i can tell your missing the "virtual-template-number" under "vpdn-group 1" also u might want to check the radius server to see if it is excepting or rejecting pppoe request to the LNS. also try removing the "local name" option.
Steve K
385
