l2tp qos marking
why I cannot use set ip dscp tunnel command in my qos packet marking for xconnect session? I do not have this command and ios is c7200-ik9o3s-mz.124-21.bin.
Re: l2tp qos marking
nobody?
Bronze
You can use this command To set the differentiated services code point (DSCP) value in the tunnel header of a Layer 2 Tunnel Protocol Version 3 (L2TPv3) tunneled packet for tunnel marking, use the set ip dscp tunnel command in policy-map class configuration mode. To disable this functionality, use the no form of this command.
set ip dscp tunnel dscp-value
no set ip dscp tunnel dscp-value
where dscp value is number from 0 to 63 that identifies the tunnel header value. The following reserved keywords can be specified instead of numeric values:
EF (expedited forwarding)
AF11 (assured forwarding class AF11)
there is no such command
636
