LAN encrption
Dear all
I have a corporate LAN
I want to encrypt my packets between my cisco switch ports.
please give your hints
Silver
Re: LAN encrption
1- Use SSL,
2- Use SSH
that will encrypt all traffics inside your corporate LAN, independent of your network.
Silver
Re: LAN encrption
Forgive me for asking this, but why are you wanting to encrypt internal traffic between switch ports?
Is it because of information between or within departments? Instead of that why would you not just create VLAN for the separate departments and then ACL the traffic, no access is granted outside the VLAN unless by the ACL.
What are you trying to accomplish?
Re: LAN encrption
this is for specific solution
its mandatory to encrypt packet while traveling between endpoints and clients
Re: LAN encrption
Hani,
I think you should be looking at the endpoints to do the encryption/ decryption, and the cisco gear to carry the traffic.
As another poster responded SSH/SSL. will happily encrypt the payload.
Tony
Re: LAN encrption
Hani,
Tony
Re: LAN encrption
We also have certain areas that require encryption. Layer 2 ports can't do it today and between multiple subnets would be a nightmare. Have the OS perform the encryption.
Silver
Re: LAN encrption
PGP is a good solution from a client to client encryption standpoint, here is a link to an article I found.
http://www.javvin.com/networksecurity/EthernetLANSecurity.html
or the link to PGP
http://www.pgp.com/
135
