02-21-2013 10:37 PM - edited 03-04-2019 07:06 PM
Dear Colleagues
Pl help me with below problem
I am trying to introduce BG router (cisco 1841) before ISP FW, (FW-BG-ISP)
After doing that and necessary routes, All services are working fine.
but there are two servers, which are not able to connect.
Both these servers, have the public IP address,
and there is cisco 3750 switch between server and FW.
Please check the diagram, and let me know for more information from any of the device, like show run or routes etc
I have invested lot of time but could not find the problem
I have wire shark captured on switch interface. if it may helpful
pl note i have amend the IPs (public IP), these are not actual,
02-27-2013 05:29 PM
Hello Abhishek.
I understand that you're facing a connectivity problem, from the server connected behind the 3750 upstream to the internet.
May I ask:
1- Who is the default gateway for those servers?
2- Are they able to ping its default gateway?
3- Is the default gateway able to go the internet?
4- If the default gateway is the 3750 can you span the SVI doing routing for the servers?
5- If the default gateway is the 1841 can you configure an access-list to see if there's hitcounts outgoing?
6- Also please attach the topology diagram back again, it appears to be corrupted or something I can't downloaded.
Regards.
Wilson
03-02-2013 01:05 AM
Thanks Wilson for picking this up.
I am attaching the diagram again
Unfortunetly I dont have access to these servers, so need to wait till get the interface config details.
Can you please elaborate more on span SVI on 3750? how to do?
03-02-2013 03:20 PM
Hello Abhishek.
I was able to opened the zip file and check the topology diagram, but I'm missing the information I requested before.
Post this informaton:
From the server:
What vlan is the server in?
Who is the default gateway of those two servers?
From the 3750
Is the 3750 acting as a layer 3 switch.
What are the two interfaces connected the 3750 to the servers and how are they configured?
What is the upstream interfaces connected to CISCOPIX? and how is it configured?
From the PIX525
Send the show version
Send the show run
From the BG router.
Send the show run.
Put all those outputs in a notepad and attached to the post, I will be looking at it as soon as I have access to that information and let you know my findings.
Wilson B.
03-04-2013 03:50 AM
Hi Wilson
I have uploaded my reply.
few are as below:
Pl note that I need to change the IP addresses, to hide the identity,
and need to modify the sh run of pix and sh run of BG, due to policy, i hope you understand
so if you do not get the information you are looking for then please let me know.
thanks
interface Vlan30
description server1
ip address 87.24.18.97 255.255.255.240
end
interface GigabitEthernet1/0/16
description beta port server2
no switchport
ip address 37.41.91.1 255.255.255.224
speed 100
end
Not sure, there is VPN connectivity, still pl wait, i am trying to collect
From the 3750
> yes
interface GigabitEthernet1/0/14
description alpha port server1
switchport access vlan 30
switchport mode access
speed 100
end
interface Vlan30
description server1
end
Current configuration : 120 bytes
interface GigabitEthernet1/0/12
description pix connectivity
switchport access vlan 40
speed 100
duplex full
end
middle-switch#sh run int vlan 40
Building configuration...
Current configuration : 82 bytes
interface Vlan40
description pix
ip address 10.200.165.4 255.255.255.192
end
name 10.200.165.1 corporate_int
interface Ethernet4
speed 100
duplex full
nameif cpt
security-level 50
ip address corporate_int 255.255.255.192
From the PIX525
GPRS-PIX# sh ver
Cisco PIX Security Appliance Software Version 8.0(4)
Device Manager Version 6.1(5)51
Compiled on Thu 07-Aug-08 19:42 by builders
System image file is "flash:/pix804.bin"
Config file at boot was "startup-config"
GPRS-PIX up 10 days 6 hours
Hardware: PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: Ext: Ethernet0 : address is 001a.2f35.704e, irq 10
1: Ext: Ethernet1 : address is 001a.2f35.704f, irq 11
2: Ext: Ethernet2 : address is 000f.a3e9.8788, irq 11
3: Ext: Ethernet3 : address is 000f.a3e9.8789, irq 10
4: Ext: Ethernet4 : address is 000f.a3e9.878a, irq 9
5: Ext: Ethernet5 : address is 000f.a3e9.878b, irq 5
6: Ext: GigabitEthernet0 : address is 000e.0cbb.07cb, irq 5
Licensed features for this platform:
Maximum Physical Interfaces : 10
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
Serial Number: 810451377
Running Activation Key: 0x713ec564 0x2c463c6b 0x0ca111d4 0xb6602c44 0x04173283
Configuration has not been modified since last system restart.
Send the show run
03-04-2013 08:35 AM
Hi Wilson
The default gateway for the server 1 is the IP address of int VLAN 30, 87.24.18.97
03-06-2013 09:26 PM
hi Wilson
tonight i have tried again, and split the access rule in firewall,
i can see hits coming from server IP towards internet,
but no hits coming from internet to server IP ranges
any clue?
03-02-2013 01:20 AM
plzz use jpg format it is corrupted
