12-18-2011 08:02 PM - last edited on 03-25-2019 03:34 PM by ciscomoderator
HI,
I am looking for The latest IOS Available for cisco 3560 Series Switch,User guide for the same And All Supported features specification Guide.
Solved! Go to Solution.
12-18-2011 08:52 PM
Configuration Examples and TechNotes
Currently, stay away from IOS version 15.0(1)SE and 15.0(1)SE1.
12-18-2011 08:52 PM
12-19-2011 07:24 PM
HI Leolaohoo,
Thakns for your valuable Support,
12-19-2011 07:54 PM
Thanks for the ratings Amit.
12-20-2011 02:08 AM
Hi leolaohoo,
why you have stated above sentance, is there any prob with ver 15.0(1)SE1 ?
12-20-2011 12:56 PM
15.0(1)SE has a memory leak. Cisco released a fix, 15.0(1)SE1, on 02 December 2011 but was quickly pulled on 15 December 2011 because they "found" something sinister.
The link to 15.0(1)SE1 has been re-instated yesterday, 20 December 2011, the 02 December 2011 and 20 December 2011 files are different. So if you have downloaded the file prior to 20 December 2011, Cisco recommends that you download the new file.
I don't have any idea why the Cisco developers are re-using the same filename.
12-20-2011 07:09 PM
Hi leolaohoo,
okk,
Thanks For your Support,
01-02-2012 03:24 PM
Mysterious things happened during the Christmas holidays.
The 20 December 2011 version of the 15.0(1)SE1 has been "pulled". On 23 December 2011, this file has been replaced by 15.0(1)SE2. The original 02 December 2011 file of 15.0(1)SE1 is still there.
I am suspecting the 15.0(1)SE2 is the 20 December 2011-version but is renamed to reflect the intention.
