Layer 2 over L3 with loadbalancing, maybe challenging
Hi Experts,
i'm trying to accomplish the following:
(please look at the attached image).
I want to trasport a bunch of vlan layer 2 etherchannel on a pair of layer3 connections, using L3 to load balance.
i was considering a pair of options:
1) bridging + gre (non applicable since i cant bridge 2 interface beloging to a etherchannel to a tunnel)
2) L2TP
is it possible to accomplish this with the above tecnology? any reference, configuration example?
3) AoMLPS
is it possible to accomplish this with the above tecnology ? any reference, configuration example?
I cant modify topology, the routers used are ASR1001
It is mandatory that both sites have a layer2 connection between them.
If this is not the appropriate forum category, can you point me the correct one?
Andrea
1 REPLY
to add further information, the etherchannel carry a dot1q trunk with a small set of vlan
Andrea
156
