Webcast-Catalyst9k
Lease line and ADSL
Dear Sir/Madam,
My network as follows:
ISA 2004-10.0.0.1----10.0.0.2-Router 1841--
-----------lesse line
I
-----------ADSL
I want all users access internet through ISA 2004, all traffic out to lease line and only web &FTP traffic out to ADSL.
I configured but not run.
Can you help me!
Thanks a lot,
Nhuong Pham
Current configuration : 2318 bytes
version 12.3
hostname VTI
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
username xxx privilege 15 secret xxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip domain name vti.com
ip name-server 203.162.4.1
ip name-server 203.113.131.1
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
no ftp-server write-enable
interface FastEthernet0/0
description connected to EthernetLAN
ip address 10.0.0.2 255.0.0.0
ip nat inside
ip tcp adjust-mss 1452
ip policy route-map TRAFFIC
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description connected to VDC
ip address 222.x.x.x.255.255.252
ip nat outside
interface ATM0/1/0
description connected to Viettel
ip address dhcp hostname viettel
ip helper-address 203.113.131.1
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxx
ppp chap password xxx
ppp pap sent-username xxx password xxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 5 interface Dialer1 overload
ip nat inside source static 10.0.0.1 222.255.74.108
access-list 5 permit 10.0.0.0 0.0.0.255
access-list 101 permit tcp any any eq ftp
access-list 101 permit tcp any any eq www
access-list 102 permit ip any any
dialer-list 1 protocol ip permit
snmp-server community string RO
snmp-server enable traps tty
route-map TRAFFIC permit 10
match ip address 101
set interface Dialer1
route-map TRAFFIC permit 20
match ip address 102
set interface Serial0/0/0
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
end
1 REPLY
VIP Purple
Re: Lease line and ADSL
can you specify what is not working ? Your config looks ok, provided the clients send their web traffic to the ISA server first, and the ISA server then sends the web traffic to FastEthernet0/0.
A possible problem might be that you send www traffic out the ADSL interface, but not DNS traffic (which is necessary to resolve web addresses). Can you try and add the following to access list 101:
access-list 101 permit tcp any any eq 53
and see if that makes a difference ?
GP
180
