level 5 passwords
cfajardo1_2
is there any way i could break level 5 passwords on cisco routers?
thanks
Richard Burts
Celso
The type 5 passwords are protected by MD5 and as far as I know there is not any way to break them.
Depending on what type of password it is, you can probably use the password recovery procedure and replace the password with a new password. But I do not think that you can break the existing password.
Rick
Rick
6 Replies 6
Richard Burts
Celso
Rick
Rick
level 5 passwords can't be broken.
level 7 passwords are easily broken.
HI avmabe,
Can you please Post the Steps to break the "Level 7" Password in CISCO Router.
Thanks in Advance for Help
Best Regards,
Guru Prasad R
Hi Guru,
you can do that with the help of solarwinds, try downloading the 30 dayz trail version & there u can find "decrypting the cisco password" for level 7. hope this helps.
rate this post if satisfied.
actually all passwords can be broken :0)
If you know how to reverse an MD-5 string...
You can attack MD-5 with many programs on the net, you will need to brute force them, so the longer and more complex your enable secret the better... check this...
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801f2336.shtml
Cisco actually offering another type of password, knowing md-5 / type5's are vulnerable.
Philip D'Ath
I've written both type 7 and type 5 password crackers in javascript that can run in your web browser (Google Chrome is faster on type 5 at the moment).  Type 5 is a bit of a challenge in javascript unless the password is particularly weak.
