Community Member
Limit of virtual Mac addresses used on same physical interface
When using HSRP on subinterfaces , Is there a limit of number of virtual Mac addresses used under same physical interfaces ?
The setup : multiple fast ethernet subinterfaces under the same physical interface .HSRP is to be configured on every subinterface .
1 ACCEPTED SOLUTION
Silver
Re: Limit of virtual Mac addresses used on same physical interfa
There is no such restriction on the number of subinterfaces running HSRP. Only restriction for HSRP in Subinterfaces is that the HSRP groups on subinterfaces must have a group number unique among all other groups on all subinterfaces on the same main interface. This is because subinterfaces do not receive a unique SNMP interface index. If you had two groups with the number N on different subinterfaces, then in the MIB, group N on sub-interface 1 and group N on sub-interface 2 would appear to be the same group.
1 REPLY
Silver
131
