Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Link utilization is very high at Serial Interface
I found that the link utilization is very high at the serial interface.
Serial0/0/0 is up, line protocol is up
Hardware is GT96K Serial
Description: E1 PPP to CNHNGPEEDS101 Ckt ID: Asianetcom EDL-0017
Internet address is x.x.x.x/30
MTU 1500 bytes, BW 1984 Kbit, DLY 20000 usec,
reliability 255/255, txload 106/255, rxload 249/255 =========> Heavy utilized
Encapsulation PPP, LCP Open
Open: IPCP, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 17:12:20
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 334 ======> Pakcets drop due to circuit fully utilized
Queueing strategy: weighted fair
Output queue: 0/1000/64/334 (size/max total/threshold/drops)
Conversations 0/174/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1488 kilobits/sec
5 minute input rate 1944000 bits/sec, 464 packets/sec
5 minute output rate 828000 bits/sec, 502 packets/sec
7101691 packets input, 720372677 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
5587587 packets output, 951038153 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
I want to know what kind of traffic caused this problem. Any command for router to get that information?
Sam
1 REPLY
Re: Link utilization is very high at Serial Interface
hi,
you can enable netflow using 'ip route-cache flow' on the serial interface and then use 'show ip cache flow' to view the different traffic flows going through the interface. alternatively you can use 'ip accounting output-packets' on the interface and 'show ip accounting'. netflow will show incoming flows whereas accounting will show outgoing packets.
hope this helps.
take care.
322
