Community Member
LLQ Help Required
I want to configure LLQ so that one user get fix amount of bandwidth but still not able to configure it see the belwo mention configuration for LLQ
I want to configure LLQ on my Router which has 2 FE interface.
I want only specific application 10.1.4.3 always gets Bandwidth 74990 in either case. and one user get 8 kbps.
I configure the router with below mention command but still not able to get the desired result.
both users are able to get bandwidth in MB and no LLQ is working.
version 12.4
class-map match-all testclass2
match access-group 160
match access-group 150
policy-map testpolicy
class testclass
priority 8
class testclass2
priority 74990
interface FastEthernet0/0
bandwidth 8000
ip address 10.1.3.1 255.255.255.0
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.4.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.3.2
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 150 permit ip host 10.1.4.3 any
access-list 160 permit ip host 10.1.4.5 any
Router-C#show policy-map interface fastEthernet 0/0
FastEthernet0/0
Service-policy output: testpolicy
Class-map: testclass (match-all)
91678 packets, 5680284 bytes
30 second offered rate 698000 bps, drop rate 0 bps
Match: access-group 150
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 8 (kbps) Burst 200 (Bytes)
(pkts matched/bytes matched) 9/612
(total drops/bytes drops) 0/0
Class-map: testclass2 (match-all)
144133 packets, 8696430 bytes
30 second offered rate 898000 bps, drop rate 0 bps
Match: access-group 160
Queueing
Strict Priority
Bandwidth 5990 (kbps) Burst 149750 (Bytes)
(pkts matched/bytes matched) 22/1251
Class-map: class-default (match-any)
27 packets, 2235 bytes
30 second offered rate 0 bps, drop rate 0 bps
Re: LLQ Help Required
HI Wasim, [Pls Rate if HELPS]
class class-default and fair-queue are missing.
class testclass
priority 8
class testclass2
priority 74990
class class-default
fair-queue
? Service-policy output testpolicy
The above was not applied in any of the Interface ?
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Community Member
Please see the updated configuation i have modified it but still not able to restrict the user,
Building configuration...
*May 29 15:25:44.768: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1247 bytes
version 12.4
hostname Router-C
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool users
network 10.1.4.0 255.255.255.0
default-router 10.1.4.1
voice-card 0
no dspfarm
class testclass
priority 8
class testclass2
priority 5990
class class-default
fair-queue
duplex auto
speed auto
service-policy output testpolicy
duplex auto
speed auto
ip classless
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router-C#
Router-C#sh run
version 12.4
hostname Router-C
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip dhcp pool users
voice-card 0
no dspfarm
class testclass
priority 8
class testclass2
priority 5990
class class-default
fair-queue
duplex auto
speed auto
duplex auto
speed auto
ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
I m trying to restrict the user to bandwidth 74990 but still failling user is able to download in MB
Community Member
can anyone help me out
Super Bronze
Recently I stumbled across Cisco LLQ documentation that the implicit policer only rate limits when there's interface congestion. The simple solution would be to add a police statement within the LLQ class so the class will never exceed its allocated bandwidth regardless of whether other traffic causes interface congestion. Something like:
class testclass
priority 8
police 8000
class testclass2
priority 74990
police 74990000
Bronze
Hi Wasiim,
As said by Joseph, please remember that QoS queuing policies(not even LLQ) never kicks in if you don't have congestion. If your bandwidth utilization is low, then never expect any participation of QoS.
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Totally agree with Joseph and Ashok. The action of policing with LLQ depends upon if there is congestion > Policing will only be done if congestion occurs - with no congestion if the bandwidth required is more than the priority it won't be policed - but the extra packets will not be moved from the tail to the head of the queue (prioritized) like the conforming bandwidth, meaning that only the conforming bandwidth is prioritized and moved from the tail to the head of queue regardless there is congestion or not - implying that the prioritization is what is always policed and not the packet flow.
BR,
Mohammed Mahmoud.
Community Member
thanks for the useful information. few more questions, I will have 6 MB bandwidth on my internet rotuer, I want that only specific traffic of video conferenceing server always get 386 KBps bandwidth.
will that above mention configuration will in live enviroment.
I have vsat link, which is terminate on Gigabit ethernet interface, is there any need to change the bandwidth on physical interface which is 1000 Mbps to actually bandwidth of 6 MB or leave it as it is
Hi wasim,
Changing the bandwidth command will not change the actual bandwidth that ISP has provided.It's hard to make the gigabit interface to get congestion. If you want to restrict the bandwidth all the time then policing is good way to go. Joseph provided a good one.
Thot
Super Bronze
If you want to provide a minimum guarantee of bandwidth for some traffic, that can be accomplished by the bandwidth statement within a CBWFQ's class. If you want to limit the bandwidth within the CBWFQ class, then you want to shape or police it.
Whether or not to manage your gig interface that you know will be reduced to 6 Mbps depends on whether you expect traffic above 6 Mbps to create quality issues and whether you can manage such a situation better. (Usually I find the answer is yes to both questions. In your case, you might benefit from something as simple as a 6 Mbps shaper on the gig interface leading to the vsat link.)
Community Member
Thanks for the reply, you mean to say there is no need to change anything on gig interface.
I have to make the policy and reserve the bandwidth and apply that policy on the gig interface. nothing to change not even bandwidth on the interface.
class testclass2
priority 386
class class-default
fair-queue
interface gig0/0
duplex auto
speed auto
will that confiugration give 368 BW to this source in any case, and rest of the traffic treated as normal.
I will just apply this policy on interface nothing else is required on interface.
Super Bronze
No, if you're going to apply any policy at all, and you know the bandwidth is constricted downstream, then you should shape for that restriction.
e.g.
(Something like)
class testclass2
priority 386
class class-default
fair-queue
policy-map vsat-shaper
class class-default
shape 6000000
service-policy testpolicy
interface gig0/0
duplex auto
speed auto
service-policy output vsat-shaper
The above will guarantee your host at 10.1.4.5 with at least 368 Kbps of bandwidth, with priority queueing. All other traffic will FQ all other available bandwidth, up to 6 Mbps.
Correct me if I'm missing something over here:
1. I dont see any Service-Policy command on either of the interface
2. If you are assigning more than 1 LLQ in a given Policy-Map, I guess the Router will combine the LLQ and make it one.
If I were you, I would have given the 8kbps traffic LLQ and the 74990 kbps traffic CBWFQ so that former one would get guaranteed bandwith.
HTH,
Please rate all helpful posts
Kind Regards,
Wilson Samuel
Community Member
If u see above I have applied the service policy on interface gig 0/0.
170
