LNS Hardware recommendation
Looking at the most scalable alternative for an LNS - We have looked at 7200's (Starting with NPE400, then potentially upgrading to NPE-G1 as required).
Would 7600's be a better alternative?(Or 6400's?)...Or is there a new Cisco product that replaces the above?
MB
Re: LNS Hardware recommendation
Cisco 7200 with NPE G1 will be a best bet for this requirement though 7600 with dual sups cant be overlooked or sometimes may appear a overkill if u dont have enough traffic feeds ...
About 6400 broadband aggregators as per cisco it has already reached EOS and EOL status and hope u can settle down between 7200 or 7600..
Do refer this link for the EOS/EOL notification on 6400..
http://www.cisco.com/en/US/products/hw/routers/ps314/tsd_products_support_eol_series_home.html
regds
you might also want to look at Cisco 7300 or Cisco 10000. Here is a link to a performance test.
Miercom Performance Testing for Broadband Aggregation
http://www.cisco.com/en/US/products/hw/routers/ps352/prod_system_test_report0900aecd8009e960.html
In the end it depends on your budget and the requirements you have. Nearly every Cisco router has L2TP capabilities.
Hope this helps
Thanks for the info guys.
197
