Load balacing on head office
I have two connection lease line @ my branch office which is connecting to my main office, and currently I am using static routes on branch office. I am looking for load balance on the both link, for example traffic should parallel pass on both link instead of failover connection. Any suggestion please.
Basharath Khan
Re: Load balacing on head office
You can use 2 static routes for the destination traffic with one pointing to 1st link and the 2nd to the redundan link
http://www.inetdaemon.com/tutorials/internet/ip/routing/static/index.shtml#loadbalancing
HTH, rate if it does
Narayan
not sure i understand what you mean?
narayan trying to say that configure the two static route with same AD pointing towards the destination.
for example you have the destination 192.168.1.1 is connected using two link through same source then you can use two stati route.
regards
Devang
i see, so by using the same ip address on both static routes on both interfaces, this will load balance?
you will also need to add these commands on the outside interface:
ip load-sharing per-packet
OR
ip load-sharing per-destination
Can you post your topology
That will help us to give you the right solution
Narayan
141
