Community Member
Load Balance 2 DSL - do not want mlppp
Hi All
How do I configure router (2801) to load balance 2 adsl lines? I'm guessing I need 2 x dialer interfaces? and then I create 2 static routes? Is it as simple as that?
We have 2801 with 2 x dsl that we used to bond but ISP is pulling the bonded ADSL service due to problems. So I'll end up with 2 separate accounts instead. That's ok as we don't have high volume anyway. But how do I configure the router to load balance between the two connections?
Both connections will have separate account logins and separate public ip addresses.
Thanks in advance.
Anthony
1 REPLY
Re: Load Balance 2 DSL - do not want mlppp
There was another post on this today. There, the following link was given:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml#conf
Should give you a good start I presume!
regards,
Leo
197
