01-17-2012 03:59 PM - edited 03-04-2019 02:56 PM
I have two offices in rural area with a quite distance between them. Offices are connected with private wireless 100Mbps and cooper 100Mbps links provided by different ISP. Wireless connections are delivered as a private L3 Ethernet link but cooper as private L2 Ethernet trunk link. In both offices I have Cisco 3750 L3 switches. I would like to use both link (equal-cost paths) in load balanced configuration but not sure how. Both switches running EIGRP. Asymmetric routing is not an option. Per-destination load-balancing or something else?
Any help is appreciate
01-17-2012 06:07 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Not quite sure how you avoid asymmetrical routing when load balancing. Could you clarify this requirement?
01-18-2012 08:12 AM
I'll be sending voice traffic via these links. Can somehow load balancing be symmetric or do I have any other solution to aggregate these two links?
01-17-2012 07:16 PM
could you route the copper Ethernet link? If so you could adjust the metrics to be equal cost at which point load balancing would be automatic.
01-18-2012 08:54 AM
If on both link cost are equal (as per EIGRP resulted metric from both links) then EIGRP will do load-balancing by default.
However if both links cost are resulted in not equal metrics, then you can enable unequal cost load-balancing, please follow the Cisco documentation.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009437d.shtml
I assume this is how your offices are connected.
|-------wireless------ | __
| Office A | | Office B |
| |______wired____| |
Rizwan Rafeek
01-18-2012 09:38 AM
I don't think that 3750 switches can do unequal cost load balacing.
One would need a true router for that, an is not a good idea anyway.
