Load balancing 1841 with 2 adsl wic's in the same lan.
alvergam39
I have Cisco 1841 router with 2 adsl wic's ,2 Internet connections from the same ISP and i 'd like to do load balancing per-destination in the same lan. I have IOS 12.4(1a).
I 'm trying to set up fastethernet0/0 , 2 atm's and 2 dialers.
I want to setup with nat inside in fastethernet0/0 and nat outiside on both dialers,with pap authentication pvc 8/35 , ip address negotiated on dialers,
encapsulation aal5mux ppp dialer.
Can you help me with the config file?
5 Replies 5
nethelper
Level 3
Level 3
here is a sample configuration for your setup.
ip cef
interface FastEthernet0/1
ip nat inside
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no ip route-cache
pvc 8/35
dialer pool-member 1
interface ATM0.2 point-to-point
no ip route-cache
pvc 8/35
dialer pool-member 2
interface Dialer1
description ISP1_Connection_1
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username USERNAME password PASSWORD
interface Dialer2
description ISP1_Connection_2
ip mtu 1452
encapsulation ppp
dialer pool 2
dialer-group 1
ip nat inside source route-map ISP1_Connection_1 interface Dialer1 overload
ip nat inside source route-map ISP1_Connection_2 interface Dialer2 overload
access-list 1 permit 192.168.1.0
route-map ISP1_Connection_1 permit 10
match ip address 1
match interface Dialer1
route-map ISP1_Connection_2 permit 10
match ip address 1
match interface Dialer2
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
dialer-list 1 protocol ip permit
Nethelper
Thank you very much nethelper.
I 'd like to ask you about the physical atm interfaces atm0/0/0 and atm0/1/0 .
I do not configure the atm0/1/0 interface ?
I have 48 pc's in the lan.
All the pc's they 'll share both connections from atm0/0/0 ?
For example:
PC01 going internet from connection ISP1
pc02 going internet from connection ISP2
pc03 going internet from connection with less load.
Best Regards
alvergam39
the sample configuration given is based on two PVCs on the same physical interface. In your case, with physical interfaces ATM0/0/0 and ATM0/1/0, the configuration would look like this:
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface ATM0/0/0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 8/35
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface ATM0/1/0.2 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 8/35
The load balancing is per-destination (which is the default). That means that e.g. PC01 going to www.cisco.com will go through ISP1, PC02 going to www.microsoft.com will go through ISP2, and so forth.
Nethelper
Thank You again nethelper .
You help me a lot,and your configuration file was right.
Best Regards
alvergam39.
Hello again nethelper
Thank you very much for your config.
I have a little problem with DHCP server in my Lan.
I have a DHCP server in my network at 192.168.0.1 , and when i plugging the router on the lan i havent internet .
It must work as relay agent ?
Can you help me with this .
Best Regards
alvergam39
