Community Member
Load Balancing and Failver between 2 ISPS
the conversation title explains it all but let me mention more details
I have 2 ISP Feeds, Right now we are going through one PIX Firewall which is behind one of the ISP ADSL Routers
My Question , what solution can you guys give me if i want to Load balance between these 2 ISP links
Since we have one PIX i am assuming we might need to put a Router in front of the PIX so one interface can be connected to the PIX and the other 2 can go to the ISP DSL Routers
i am assuming we can achieve this using Static Routes
but since you'll know the routers come with 2 Eth Interfaces
is it possible we can assing two ISP Addresses on one Interface as Primary adn Secondary and Configure static routes
Please i need a good soultion , i have stormed my brains thinking your help would be highly appreciated at the earliest
Re: Load Balancing and Failver between 2 ISPS
the link for more information about this Long Distance Application Failover Solutions Guide.
Bringing high availability to a global basis requires a global load balancer or content router. The Cisco GSS interacts with your Domain Name System (DNS) infrastructure to resolve DNS requests to an IP address that corresponds to the virtual IP address content switch or server load balancer that is closest based on the following criteria:
Intelligent load-balancing algorithms and "clauses"
Proximity to user request
Data center and server loads, availability, and health
Persistence to prevent lost session information
