Load Balancing Eigrp
Hello, Got Stuck in getting load-Balancing working with Two GRE tunnels from Hub pointing two GRE Tunnels on Spoke using EIGRP.
show interface summary indicates traffic on one tunnel only, unless manually shutdown traffic not seen on other tunnel.
Any suggestion
  • WAN Routing and Switching
Re: Load Balancing Eigrp
Attached the configuration.
Hall of Fame Super Silver
Hello Nasr,
the two tunnels have different parameters:
tunnel2 has BW 5000 kbps, tunnel1 has BW 2000 kbps.
EIGRP metric uses cumulative delay and inversely proportional to lowest delay on path.
EIGRP can perform un-equal cost load balancing but you need to add
router eigrp 7
variance 3
(under the hyphothesis that delays are equal on the two tunnels you can check with sh int tunnel 1 and sh int tunnel 2).
To perform equal cost load balancing you need to put the same bandwidth command
Hope to help
Giuseppe
Thank you.
Can you explain variance 3
Tunnel2 has higher bandwidth. Can hosts on spoke use Tunnel2 to pass critical application(HR application running on oracle) and other traffic on Tunnel1.
HR application is running on Server 192.168.205.10 at HUB Site
Spoke with IP 172.17.17.0/24
Hello Nasr,
the variance 3 allows EIGRP for unequal paths lod balancing with the two metric that can be in a ratio up to 3.
in your case 5/7 of traffic would go on faster link tunnel2 and 2/7 on tunnel1.
but this is flow based not application based.
you need policy based routing to make this kind of traffic engineering based on application types.
Or more simply an host static route like
ip route 192.168.205.10 255.255.255.255 tunnel2
this can work on the spoke to hub direction
PBR is needed on hub site
access-list 11 permit host 192.168.205.10
route-map pbr_oracle permit 10
match ip address 11
set interface tunnel 2
on lan interface(s) on hub router
int fas0/0
ip policy route-map pbr_oracle
Hope to help
Giuseppe
This is the complete picture, sorry I should have put the complete diagram.
Host 192.168.205.10 is on Backbone Switch, behind the VPN router.
Other Spokes(spoke2/spoke3/spoke4) also access this server from different location via different Tunnels.
HUBBackBone----HubVPNRTR----Internet---spoke1VPNRTR-----LAN
HUB-Backbone
interface vlan66
description servers
ip address 192.168.205.1 255.255.255.0
I think PBR needs to be applied on BackBone VLAN, but will this impact other Spokes.
Hello Nasr,
yes if multiple point-to-point tunnels exist PBR cannot be used.
the only possible way is to have specific static routes but this can only work if only some clients access the server.
Otherwise you cannot do this on the routing level.
QoS can help in providing a better treatment to oracle application
Hope to help
Giuseppe
If I have a dedicated Router with tunnels pointing to this specific spoke then PBR would work. Is this correct.
But do I need to apply any additional commands on the vlan which has Oracle Server.
Hello Nasr,
you should terminate all tunnels "2" for each remote site in another router at central site.
the current node would then need a PBR to the second device configured in the vlan where the Oracle server is connected.
It is becoming a complex solution, but you can achieve redundancy at central site in this way.
Edit:
an alternative way could that of changing the point-to-point GRE tunnels into two multipoint GRE so that you could use a single interface on hub site to address the tunnel 2 DMVPN cloud.
Hope to help
Giuseppe
166
