Load balancing in OSPF Process
We are having problem with load balancing in OSPf enabled network.
We have adjusted ospf cost of the destination network so that we can see show two routes of equal cost to the destination network in , show ip route command.
One path is via a serial link connceted to destination router and another path is via ethernet to another router which is turn has serial link to destination router. But when we check the link utilizations only one link was showing traffic and other link was free. Do we need to configure any thing more to load balance in OSPF when it has two paths of equal cost to destination network.
Any link on cisco.com for configuration example of load balance in OSPF is highly appreciable !
Thanx in advance
Subodh
1 REPLY
Re: Load balancing in OSPF Process
have a look at "How Does Load Balancing Work?"
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
This could really explain your situation or tell you where to start trouble shooting.
Regards, Martin
124
