Load Balancing on 7606
i have multiple E1 links. i need to load balance but this platform supports only per destination which does not fullfill the requirement. The voice is running on this network. If anyone has any idea do share.
NOTE: NO MLPPP
JB
Re: Load Balancing on 7606
hi
Keeping Voice traffic in your network its better to go with per destination load balancing instead of per packet.
Per destination is recommended by cisco if you have Voice traffic running in your network.
So i would better suggest to go with per destination load balancing here..
regds
Actullay there are multiple(8) point to point links between 7606's. In the peak times, one of the links are choked (95%) while other links are less utlized (60%). This cause the problem for voice calls which are on choked link and some time is not possible to connect a new calls.
regards
JB
240
