04-15-2015 12:48 AM - edited 03-05-2019 01:15 AM
Im trying to achieve load balancing with 2 ISP's, cable (dhcp) and ADSL. I have a cisco 2821 router with an HWIC-1ADSLI module.
LAN is a single C class subnet. I have tried following this cisco advisory to the letter:
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/99427-ios-nat-2isp.html
But with that setup...nothing works, i have no internet access, no routes in routing table, and both tracks are down.
Then i tried using this:
track 1 interface Dialer0 ip routing
track 2 interface GigabitEthernet0/1 ip routing
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 track 1
And NAT with route maps. This way i got both routes in the routing tables, and tracks are up, but all clients are getting internet access trough one of the ISP's, and when i disconnect it it takes cca 20 seconds to other one to kick in....so there is no load balancing and even as a failover its a crappy solution because downtime is so long. And also:
ping 8.8.8.8 repeat 110
Sending 1000, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 36 percent (40/110), round-trip min/avg/max = 32/32/36 ms
My original idea was to use PBR, but since i dont have fixed next-hop (i have to use set interface) address i cant use "verify-availability".
If you have any advice how to achieve 50-50 load balancing with this setup please help. Thanks in advance.
04-15-2015 12:50 PM
The way I resolved a similar issue was with Policy Based Routing (PBR), here is a link to a discussion I started. This has a working config with the described error. If you use PBR you will only need one default route in the table. PBR will route the clients until the link fails, the only thing you need to do is determine which link is the more reliable. I would make the sole default route to this ISP.
https://supportforums.cisco.com/discussion/12400601/routing-issues-ip-sla
Hope this helps.
Sam
04-15-2015 11:56 PM
Using PBR would be awesome, like i said it was my first idea, but since IPs are dynamic for both ISP links i cant use the command :
set ip next-hop verify-availability
So i wont have failover.
04-16-2015 01:24 AM
Hello
Your tracking config it doesnt seem correct-.
If your using two static default routes then apply track on the priamry default only.and apply a lower admin distance to that primary than the secondary default.
You can either use ip sla with tracking , or just track on the interface.
ip sla 1
icmp-echo x.x..x source-ip y.y..y
frequency 5
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
or
track 1 interface dialer 0 line-protocol
ip route 0.0.0.0 0.0.0.0.0 Dialer0 track 1 200
ip route 0.0.0.0 0.0.0.0.0 GigabitEthernet0/1 250
res
Paul
04-16-2015 01:25 AM
there ws mistake in typing in my post, should be:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 track 2
Anyway, your suggestion would mean i have failover, but no load balancing. i want to achieve both.
04-16-2015 02:03 AM
Hello
ip route 0.0.0.0 0.0.0.0.0 GigabitEthernet0/1 200
res
Paul
04-16-2015 03:10 AM
After doing that:
ping 8.8.8.8 repeat 10
Sending 10, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 40 percent (4/10), round-trip min/avg/max = 28/28/28 ms
04-16-2015 04:13 AM
Hello
I would say reason being is the return traffic -if you close one link down this doesnt occur?
Without dyanmic routing in place such as BGP or OER - I cannot see how you can maniulate the return traffic from the isp's for specific prefix preferance
Is this what you require?
res
Paul
04-16-2015 04:32 AM
If i close one link it takes 20 seconds of downtime and then ping goes without loses.
In the end i decided to go with PBR, since the deadline for our project was surpassed.
I set up acl that matched every other 32 adress block:
10 permit ip 192.168.100.32 0.0.0.31 any
20 permit ip 192.168.100.96 0.0.0.31 any
30 permit ip 192.168.100.160 0.0.0.31 any
40 permit ip 192.168.100.224 0.0.0.31 any
50 deny ip any any
Set a route map that sends that traffic trough one of the interfaces (Gi0/1) and let routing do the rest:
ip route 0.0.0.0 0.0.0.0.0 GigabitEthernet0/1 10
Its not exactly what i wanted but its close enough:)
Thanks for your advices.
