Load Balancing over 2 ISP conncetions
shivgahlot
I have 2 routers with 1 Mbps internet connection on each. Now I have to do the load balancing between these routers without any inetrnet load balancer.
Please suggest how can I achieve this ???
guruprasadr
Level 7
Level 7
HI Shiv, [Pls RATE if HELPS]
Load balancing is not possible in a multihomed environment with two ISPs. BGP selects only the single best path to a destination among the BGP paths that are learned from different ASs, which makes load balancing impossible. . However, load sharing is possible in such multihomed BGP networks.
Refer useful link below describing multiple scenario's of BGP environments:
http://cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
tajuddinmd
Hi Shiv,
What WAN interface is your internet connection is and what is the routing protocol. ans also let your router model.
Taj
In this case another way to investigate, to load balance traffic with two or more ISPs, is the Performance Routing (PfR, named also OER, Optimize Edge Routing):
http://www.cisco.com/go/pfr
Andrea
Hi all,
i have configured oer on a 2811 with two adsls over the same ISP.
Everything works fine BUT... ftp Sessions from inside to outside cannot open!!
Any ideas how to solve this?
here is my config:
LB_2811#
LB_2811#sh run
Building configuration...
Current configuration : 3310 bytes
! Last configuration change at 15:39:00 EET Wed Dec 3 2008 by dataways
key chain key1
key 1
key-string xxx
voice-card 0
oer master
max-range-utilization percent 10
logging
border 213.140.137.188 key-chain key1
interface FastEthernet0/0 internal
interface Dialer1 external
interface Dialer2 external
learn
throughput
delay
periodic-interval 1
monitor-period 2
prefixes 200
aggregation-type prefix-length 32
oer border
logging
local FastEthernet0/0
master 213.140.137.188 key-chain key1
u
description ### Connected to ASA External ###
ip address 192.168.1.18 255.255.255.0 secondary
ip address 213.140.137.188 255.255.255.224
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface ATM0/1/0
no ip address
pvc 8/35
dialer pool-member 2
interface Virtual-Template1
no ip address
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username XXXXXX
interface Dialer2
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 2
dialer-group 1
no cdp enable
ppp pap sent-username XXXXXXXXX
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT_Traffic interface Virtual-Template1 overload oer
ip access-list extended NAT_Traffic
permit ip host 213.140.137.189 any
permit ip 192.168.1.0 0.0.0.255 any
permit ip host 213.140.137.187 any
dialer-list 1 protocol ip permit
