Load balancing over Internet link
tarunavakonar
i have 2 internet link, both are in different pool
i want 1 link using for one proxy and another one for another proxy
i have one port connectivity between FW & Internet router
i am using NAT FW(Private to public) as well as internetrouter(public to public)
now i want failover over both link, if one link is goes down traffic shifted to another link.
plz suggest me the solution over PBR
Hi Tarunava,
Are you connecting to 2 ISPs? Public IP address that you nat on the firewall belonging to ISP1 or ISP2? If so you can nat only on one ISP.
Seems you need to seperate the traffics by using the services/ports.Let's assume that you want to Nat both links with each pool ip address.
ip access-l ex Proxy-80
permit tcp host any eq 80
ip access-l ex All-Traffics
permit ip host any
route-map input permit 10
match ip address Proxy-80
set interface RouterInterfaceToISP1 RouterInterfaceToISP2
route-map input permit 20
match ip address All-Traffics
set interface RouterInterfaceToISP2 RouterInterfaceToISP1
Interface
ip policy route-map input
route-map interfaceISP1 permit 10
match interface RouterInterfaceToISP1
route-map interfaceISP2 permit 10
match interface RouterInterfaceToISP2
ip nat inside source route-map interfaceISP1 pool Pool-ISP1
ip nat inside source route-map interfaceISP2 pool Pool-ISP2
int Interface
ip nat inside
int Interface
ip nat outside
int Interface
ip nat outside
Hopes that makes you some idea.
Thot
michaelchoo
Do you have your own address space allocated from IANA? If you're not sure, ask your ISP(s).
If you do have your own block of IANA-allocated addressing, you might want to consider getting a public BGP AS from IANA and run BGP with your ISP(s). If all you need is the ability to automatically fail over, BGP can definitely do it easily for you. Load balancing is tricky though, especially if you're connected to multiple upstream ISPs.
