Load balancing/Policy Based Routing over two DSL lines
Hi, need some help with this please...
I have a router 2600 which has 2 DSL lines out (2 Dialers) and 1 Fast Ethernet interface in with many sub-interfaces. The sub-interfaces are represent the different companies that are inside this big building....
The second Dialer, is, at the moment not being used (see attached configuration) so...
Ideally, what I would like to do is to to establish some Policy Based Routing so I can decide what company (sub-interface) goes out of what DSL line..so I tried something like the following...
route-map OutDialer2 permit 10
match ip address X X X
set interface OutDialer2
interface fa0/0.161
ip policy route-map OutDialer2
But this does not seem to be working. I wonder if it is because all the NATting that the router is doing i.e. the traffic needs to come back through the same Dialer that it went out...
Do I have to get rid of the default route 0.0.0.0 0.0.0.0 Dialer1 OR do I have to have two default routes one for Dialer1 and one for Dialer2
Would it be easier to apply some kind of load balancing over the two Dialers instead of using the Policy Based Routing??
Any help will be very much appreciated
1 REPLY
Silver
Re: Load balancing/Policy Based Routing over two DSL lines
There are many first hop redundancy protocols. You can use some of these for load balacing too. Choose the appropriate protocol.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbc3.html
261
