Load Balancing Question
I am trying to load balance 2 internet circuits. One circuit comes in via a T-1 DSU port and the other comes in via a ethernet port. I can get both connections live on the 3640 router I am using. However, all the traffic wants to go out on the T-1 side and not the Ethernet side. Any help would be appreciated as I am still fairly new to config'ing Cisco routers. Here is the config as it stands right now:
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname RTR_INT1
logging buffered 32768 informational
no logging console
enable secret XXXXX
enable password XXXXXX
memory-size iomem 15
ip subnet-zero
no ip source-route
ip cef
no ip domain-lookup
no ip bootp server
interface Ethernet0/0
description To Inside LAN
ip address 65.x.x.x.x.255.240
half-duplex
no cdp enable
interface Serial0/0
no ip address
shutdown
no cdp enable
interface Ethernet0/1
description To ISP1
ip address 63.x.x.x.x.255.248
half-duplex
no cdp enable
interface Ethernet0/1.1
no cdp enable
interface Serial0/1
description To ISP2
bandwidth 1536
no ip address
ip accounting output-packets
encapsulation frame-relay
no fair-queue
frame-relay lmi-type ansi
hold-queue 75 out
interface Serial0/1.1 point-to-point
bandwidth 1536
ip unnumbered Ethernet0/0
ip access-group 100 in
no cdp enable
frame-relay interface-dlci 500 IETF
interface Serial1/0
no ip address
shutdown
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1.1
ip route 0.0.0.0 0.0.0.0 63.33.183.1
ip http server
ip pim bidir-enable
no cdp run
line con 0
password XXXXXX
login
transport preferred none
line aux 0
password XXXXXX
login
modem InOut
transport input all
flowcontrol hardware
line vty 0 4
password XXXXXX
login
end
Silver
Re: Load Balancing Question
ip route 0.0.0.0 0.0.0.0 Ethernet 0/1
And check if it works. This is because a static route to the interface gets preference over Static route to IP. But pointing to ethernet interface is not advised as it can create lots of ARP entries. I Suggest you get an IP for the Serial Link as well
I've an additional comment to say if you may allow me.
I think that it is recommended to have the static routes to the physical interfaces (not to the next hop) when applying loadbalancing.
Because in the case of static routes to physical interface when the interface goes down the route is removed from the routing table, but in the case of static route to a next hop, the route won't be removed from the routing table when the interface goes down --> causing packets to be dropped.
regards,
Mohammed
I'm afraid the previous comment is incorrect. When an interface goes down, the routing table gets reported and all the routes learned over that interface get flushed.
You could specify both the interface and the next-hop too.
Cheers
87
