Webcast-Catalyst9k
Load Balancing two Point to Point T1's
Hi, thanks for stopping by.
I'm having some difficulty load balancing two point to point T1's. This is a pretty basic transparent bridge as far as I understand it. I've followed the instructions in example 9 under doc id: 10676 to no avail. The moment I add both t1's to the circuit group I start getting problems reaching hosts on the other side of the bridge. I'll be able to ping them and then two minutes later I can't ping them at all. Then maybe a bit later I can see them again. On one side of the T1's is a 1720 and on the other is a 1721. Both are running 12.3(23). They both get updated with the circuit-group config at the same time. I think I've ruled out the T1's themselves by running the bridge on each T1 separately for some time (at least a week) without problems. But the moment I put them into a circuit group I start getting problems.
This sounds somewhat like a bridge loop maybe? Any tips on verifying this?
Here is the config from the 1720. The 1721 on the other side is basically the same config.
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname Router_Corp
boot-start-marker
boot-end-marker
memory-size iomem 25
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
interface FastEthernet0
ip address x.x.x.x 255.255.255.0
no ip route-cache
speed auto
bridge-group 1
interface Serial0
ip unnumbered FastEthernet0
no ip route-cache
bridge-group 1
bridge-group 1 circuit-group 2
interface Serial1
no ip route-cache
bridge-group 1
ip classless
no ip http server
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
end
Thank you very much!
Bob
Silver
Re: Load Balancing two Point to Point T1's
I would take fastethernet out of the bridge group and create a bvi interface.
235
