Load balancing with 1841
Hello
i have 1841 Cisco router with 2 phisical ethernets and 2 phisical atm's.
I have 2 dsl modules on 1841 and 2 dsl connections.
And i have a dhcp and domain name server in 192.168.0.1 ip.
I d like to do load balancing per packet with 1841.
Can you help me please with config?
Thank you.
1 ACCEPTED SOLUTION
Silver
Re: Load balancing with 1841
Are the dsl connection to the internet? Do they go to the same provider?
Silver
Yes.
this is what your configuration could look like:
ip cef
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface ATM0/0
no ip address
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0.1 point-to-point
no ip route-cache
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface ATM0/1
no ip address
no ip route-cache
interface ATM0/1.1 point-to-point
no ip route-cache
pvc 0/38
dialer pool-member 2
interface Dialer1
description ISP1_Connection_1
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ip load-sharing per-packet
ppp authentication chap pap callin
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
ppp pap sent-username USERNAME password PASSWORD
interface Dialer2
description ISP1_Connection_2
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 2
dialer-group 1
ip nat inside source route-map ISP1_Connection_1 interface Dialer1 overload
ip nat inside source route-map ISP1_Connection_2 interface Dialer2 overload
access-list 1 permit 192.168.0.0
route-map ISP1_Connection_1 permit 10
match ip address 1
match interface Dialer1
route-map ISP1_Connection_2 permit 10
match ip address 1
match interface Dialer2
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
dialer-list 1 protocol ip permit
Be aware of the following"
- the use of two static routes will allow load-balancing over the two links and provide redundancy at the same time
- the NAT configuration will dynamically choose the NAT'ed address depending on which interface CEF has been chosen to send the packet out of
- enabling CEF on a router will load balance outgoing traffic only, not incoming traffic. If your ISP uses Cisco, you could ask for the ISP to enable CEF on their end as well, which would result in inbound load balancing.
To verify load balancing, use the EXEC command:
sh ip cef 0.0.0.0
GNT
Gold
I was not even sure if you could use dialers with load balance by packet but the NAT issue is where I still see issues.
With 2 pools if it does as you say and nat packets based on the outbound interface you will have all kinds of problems with your sessions.
If it does load balance you will get half your packets sourced from one ip and the other half sourced from another. You will never be able to get a session working since it must have a single source and destination. The destination will discard any packets from the other source address since it did not see a sync packet and will not have a session to associate it with.
I guess you might be able to load balance by session but you seldom get good load balancing
I was speaking to a cisco rep and he said that what you are suggesting will not dynamically check the bandwidth of each WAN. Is that true?
Silver
I think I was awarded points by mistake. I only asked a question so far. Note to Moderator, please deduct them from my profile if you see this post.
-mike
Tim is absolutely right, using per-packet load balancing can cause problems with e.g. voice applications. I guess that is why the default is per-destination load balancing. So, unless you have a specific reason to use per-packet load balancing, just use the default per-destination...
GNT
I have the same load balancing question except our 1841 is connected to two different ISPs. ISP_2 has higher speed than ISP_1. We have an array of servers which has to use ISP_1 for inbound and outbound traffic.
By adding "ip load-sharing per-destination" in fa0/1 and vlan3, can I achieve load balancing? Or it won't work because the ISP are different? Thanks
Here is a partial config: (ip changed)
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
no ip bootp server
interface FastEthernet0/0
description TO-Internal-LAN
ip address 1.2.3.1 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip policy route-map ama2telus
speed 100
full-duplex
no mop enabled
description To-ISP_1
ip address 5.6.7.83 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
!Added for load balancing
interface FastEthernet0/0/0
description To-ISP_2
switchport access vlan 3
duplex full
speed 10
interface Vlan1
description defa vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface Vlan3
description Terago1
ip address 6.7.8.140 255.255.255.248
ip nat outside
ip classless
ip route 0.0.0.0 0.0.0.0 6.7.8.142
ip route 0.0.0.0 0.0.0.0 5.6.7.81
ip route 24.76.252.253 255.255.255.255 5.6.7.81
ip route 24.79.224.251 255.255.255.255 5.6.7.81
ip route 1.2.3.0 255.255.255.0 1.2.3.5
ip route 206.45.126.190 255.255.255.255 5.6.7.81
i!
no ip http server
ip nat inside source list 1 interface Vlan3 overload
logging trap debugging
access-list 1 deny 1.2.3.20
access-list 1 remark INSIDE_IF=FastEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 2 permit 1.2.3.100
access-list 2 permit 1.2.3.101
no cdp run
route-map me2ISP_1 permit 10
match ip address 2
set ip next-hop 5.6.7.81
Gold
This has a better chance to work than load balance by packet.
Your policy routing and static routes will cause those selected machines and destinations to use the ISP you selected. The rest of your outbound traffic will load balance but you still have a couple of issues.
You need to define a second nat pool. ISP1 only really knows about 5.6.7.83/29 if you send a packet with source address of 6.7.8.140
he will most likely drop it. If he does take it then the return traffic will come back via ISP2 which is not the best.
Now even after you get a second nat pool so that traffic is sourced with the proper addresses you have another issue. Some application attempt to use the IP address for security. Say for example you open a session with server 1 which has a IP of 10.10.10.1 This server tells you to go to server 2 which has a ip address of 10.10.10.2 to continue the processs. Server 1 then tells server 2 that it should accept a session from your source ip for a period of time. With load balance by destination it is very likely that you will use the other path. Server 2 will reject the session becuase the source address is wrong.
732
