Load balancing without BGP
emaamur2006
Hi all
Need a solution where my client is doing loadbalancing between client and 2 ISP, no BGP between ISP and Client, just default routes
Any ideas how i can do this
thanks
Timo
mohammedmahmoud
Level 11
Level 11
Hi Timo,
You can go for NATing:
interface FastEthernet0/0
ip address
ip nat inside
interface Serial0/0
description ***ISP1***
ip address
ip nat outside
interface Serial0/1
description ***ISP2**
ip address
ip nat outside
ip nat inside source route-map ISP1_NAT ...
ip nat inside source route-map ISP2_NAT ...
access-list 1 permit
route-map ISP1_NAT permit 10
match ip address 1
match interface Serial0/0
route-map ISP2_NAT permit 10
match ip address 1
match interface Serial0/1
ip route 0.0.0.0 0.0.0.0 serial0/0
ip route 0.0.0.0 0.0.0.0 serial0/1
HTH,
Mohammed Mahmoud.
Pavel Bykov
Level 5
Level 5
Great idea from Mohammed.
Also, if there are more than one link to the same destination from one router, it will automatically load-balance based on switching method used. For example CEF load balances per flow by default.
