load balancing
Just Kennie
Please i have two link on mi router through the WAN to the HQ. I wan to do load-balancing on the two links. I am using static routing through tunnel...how is this possible. Is PBR a better option?
royalblues
Level 10
Level 10
Can you post a little more detail about your network topology ?
However you can configure multiple static routes via each path to the destination for loadbalancing
Narayan
Giuseppe Larosa
Hello Just,
I would try to do the following:
have two static routes for the tunnel destination pointing to the two WAN interfaces.
enable load-balancing per packet on the tunnel and physical interfaces
PBR shouldn't be able to perform load balancing directly you can provie a list of next-hop but it is an ordered one with the second used if the first is not available
Hope to help
Giuseppe
Yes you are right, have two static routes for the tunnel destination pointing to the two WAN interfaces. So how do i enable load balancing per packet on the tunnel on physical interfaces.
Hello Just,
use the following:
ip load-sharing ?
per-destination Deterministic distribution
>>per-packet Random distribution
in interface config mode
Hope to help
Giuseppe
