load balancing
Please i have two link on mi router through the WAN to the HQ. I wan to do load-balancing on the two links. I am using static routing through tunnel...how is this possible. Is PBR a better option?
Re: load balancing
Can you post a little more detail about your network topology ?
However you can configure multiple static routes via each path to the destination for loadbalancing
Narayan
Hall of Fame Super Silver
Re: load balancing
Hello Just,
I would try to do the following:
have two static routes for the tunnel destination pointing to the two WAN interfaces.
enable load-balancing per packet on the tunnel and physical interfaces
PBR shouldn't be able to perform load balancing directly you can provie a list of next-hop but it is an ordered one with the second used if the first is not available
Hope to help
Giuseppe
Re: load balancing
Yes you are right, have two static routes for the tunnel destination pointing to the two WAN interfaces. So how do i enable load balancing per packet on the tunnel on physical interfaces.
Re: load balancing
Hello Just,
use the following:
ip load-sharing ?
per-destination Deterministic distribution
>>per-packet Random distribution
in interface config mode
Hope to help
Giuseppe
122
