02-09-2006 03:11 AM - edited 03-03-2019 11:42 AM
hi
i want to do load-ballance between the two atm and i don't success why?
no service pad
hostname Hadraha_Internet
boot-start-marker
boot-end-marker
enable password fprxct
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool lan
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 192.196.202.222 213.8.142.83
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
hold-queue 100 out
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/48
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface ATM0/1/0
no ip address
pvc 8/48
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 200000
dialer-group 2
keepalive 11
ppp pap sent-username xxxx password xxxx
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
keepalive 11
router eigrp 1
redistribute connected
passive-interface default
no passive-interface FastEthernet0/0
no passive-interface Dialer1
network 192.168.2.0
network 217.193.234.0
no auto-summary
ip classless
ip http server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.2.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Hadraha_Internet#
02-09-2006 03:34 AM
hi
From the config you have pasted and from the host name (Hadraha_Internet ) i feel this link is getting connected to your SP thru the dialer interfaces.
In this case you can try the following configuration...
ip nat inside source route-map Connection_1 interface Dialer0 overload
ip nat inside source route-map Connection_2 interface Dialer1 overload
route-map Connection_1 permit 10
match ip address 1
match interface Dialer0
route-map Connection_2 permit 10
match ip address 1
match interface Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Dialer1
regds
02-09-2006 03:41 AM
do i need to remove the eigrp protocol?
02-09-2006 03:47 AM
hi
If you arent running this protocol with your SP (i dont see any idea behind running eigrp with SP for internet connecitvity) you can always remove that.
But before removing that do revert back whether you are really using eigrp for any purpose over there in your network.
regds
02-09-2006 03:56 AM
do i need two dialer-list like the following ,one to dialer0 and one to dialer1?
02-09-2006 04:01 AM
Instead of two dialer-lists you can have only one
but make sure that you have dialer-group 1 under both the dialer interfaces..
regds
02-09-2006 04:29 AM
hi
your idea is good , but i have a problem with that configuration becouse that when it's one line fail there will make me lost a half of the packet.
but when i will configure with eigrp it's not occur , the eigrp will pass all the packet through the good link, so you know how i config this with eigrp.
thanks a lot.
