Webcast-Catalyst9k
load-ballance don't work
i want to do load-ballance between the two atm , and the problem is that any time the all transmit pass throuh one atm ,and it's don't do a load-ballance between the two atm.what is my problem?
no service pad
hostname Internet
boot-start-marker
boot-end-marker
enable secret xxxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool lan
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 192.110.202.222 216.8.172.83
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
hold-queue 100 out
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/48
encapsulation aal5mux ppp dialer
dialer pool-member 2
interface ATM0/1/0
no ip address
pvc 8/48
dialer pool-member 1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 2000000
dialer-group 1
keepalive 11
ppp pap sent-username xxxx password xxxx
interface Dialer2
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
keepalive 11
ppp pap sent-username xxx password xxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
ip http server
ip nat inside source route-map Connection_1 interface Dialer1 overload
ip nat inside source route-map Connection_2 interface Dialer2 overload
access-list 1 permit 192.168.2.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map Connection_1 permit 10
match ip address 1
match interface Dialer1
route-map Connection_2 permit 10
match ip address 1
match interface Dialer2
control-plane
banner login ^CCCCCCCCC
M E H I S H N E T W O R K
S n i f 888
This system is the property of Mertif Enterprise
Disconnect IMMEDIATELY if you are not an authorized user!
^C
line con 0
line aux 0
line vty 0 4
password fprxct123
login
end
Hadraha_Internet#
Re: load-ballance don't work
Suppose that all traffic is sent out on int dialer1?
This is because the first clause of your route map matches for this route. The second clause is then simply not checked while a match has already been found.
I have seen lots of people attmpting Internet load balancing. For your case it will not work because you try to split up between two different nat translations.
Best advice to achieve some balancing on this setup is to divide user in two groups and match those with different acl's. Then send one group out interface 1 and the rest out interface 2. It's not real load balancing but it is probably the best you can achieve.
Leo
In addition to the previous post, you can also try PBR to do this. PBR occurrs before NAT, therefore you can match on incoming traffic and set the interface you want. That would require to split the internal subnet. Also (if your device supports CEF) as another option, why not get rid of your route-maps altogether and allow CEF to load balance on a per source-destination basis. Routing also occurs before NAT. Instead of using ip nat inside source route-map...use ip nat inside source list. I haven't tried it but I can't see any reason why it should not work.
E.
121
