Load Share/Fail Over on 2 isp
hi guys,
can i do these setup? i have two isp but im not using bgp. suggestions?
| --------ISP1
Router |
| -------- ISP2
Thanks.
jeff
Re: Load Share/Fail Over on 2 isp
I guess you could use some float static routes and use 1 as primary and 2 as backup. You'd use only a default route towards the ISP.
check this cool link:
http://avi.freedman.net/bw/may97.html
HTH,
if it does I'd appreciate if you'd rate this post.
Vlad
Hi Jeff
We are also using the failover between 2 wan links from different ISPs. For this we are using BGP. You can take the AS no. from them.
For these setup no bgp config will be used. My problem maybe is when one connections is an E1 and the other is a dsl connection. Is these still possible ?
jeff
104
