Load sharing/loadbalencing ADSL links
Hi all
I have a internet router with 4 ADSL ports.Is there any method or seperate device to load balance or load share between these links.Thanks in advance.
Hall of Fame Super Silver
Re: Load sharing/loadbalencing ADSL links
Hello Anvar,
the routing part is relative easy:
four default static routes make the job
ip route 0.0.0.0 0.0.0.0 dialer1
ip route 0.0.0.0 0.0.0.0 dialer2
ip route 0.0.0.0 0.0.0.0 dialer3
ip route 0.0.0.0 0.0.0.0 dialer4
the most difficult part is to use NAT:
when accessing the internet private ip addresses need to be translated
given a 19268.10.0/24 internal lan you can use route-map based NAT
int fas0/0
ip nat inside
int dialer 1-4
ip nat outside
you can map 1/4 of hosts on each link
route-map nat-link1 permit 10
match ip address 1
set interface dialer1
route-map nat-link2 permit 10
match ip address 2
set interface dialer2
and son
where
access-list 1 permit 192.168.10.0 0.0.0.63
access-list 2 permit 192.168.10.64 0.0.0.63
access-list 3 permit 192.168.10.128 0.0.0.63
access-list 4 permit 192.168.110.192 0.0.0.63
ip nat inside source route-map nat-link1 interface dialer1 overload
ip nat inside source route-map nat-link2 interface dialer2 overload
ip nat inside source route-map nat-link3 interface dialer3 overload
ip nat inside source route-map nat-link4 interface dialer4 overload
Hope to help
Giuseppe
Thanks very much Giuslar for the quick response.is it possible to bundle these links together and act as a single link
Hello Anvar,
yes with multilink PPP over ATM but all DSL links must be from a single provider and you need to work with them to make it working
see
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/mlppp_over_dial.html
Hope to help
Giuseppe
Thanks Guiseppe for the link.
In the first case(witout multilink) is it possible to configure in such a way that even if one DSL link fails corresponding network be routed thru another ADSL link
As you have used the interface in the 'ip route' statement, when the interface goes down, the route will disappear from the routing table giving you what you have asked for.
Hi adamclarkuk
But each network is PATed to only one dialer interface and in the route map for this network destination is one dialer interface.In this scenario this will work?please clarify.
Your right, I missed the route-maps in the config example. hmmmm, then I am not sure.
Hello Anvar,
very good note:
the solution I proposed needs to be tuned to achieve fault tolerance (if possible).
I have to think about it.
Hope to help
Giuseppe
181
