Webcast-Catalyst9k
load Sharing on Cisco Router 1841
Dear Exper,
I would like to ask you about load sharing on Router 1841,let me tell on int f0/0 connect to ISP1(PPoE),F0/1 connect to ISP2 (Static IP) and int f0/0/0 connect to switch.and i would like to do ip address start from 10-50 go though ISP1 and ip address start from 60-100 go though ISP2.
Could you let me know how to configure and do you have sample command for this?
Best Regards,
Rechard_HK
Re: load Sharing on Cisco Router 1841
hi richard,
you can use Policy based routing to divert the traffic to first isp and rest to remaining isp.
rgds
shiva
Dear shiva,
Do you have any document? if possible could you send to me.
thanks you for your time.
Best regards,
Rechard_HK
Dear All,
Do you have any advice on load sharing on cisco Router 1841?
Best Regards,
Rechard_HK
hi richard,
this link explains how to configure routemaps and policy based routing
http://www.ciscopress.com/articles/article.asp?p=102092
rate if it helps
rgds/shiva
128
