Load Sharing using iBGP
Dipesh Patel
Level 2
Level 2
Dear Experts,
We need to implemet iBGP Load Sharing between two MPLS Service Provider -TATA and Airtel.
The Details of AS no's are mentioned in the diagram attached.
Kindly help how to configure 2 CE routers of SP and L3 switch. We do not wantto use any IGP between all these three devices.
Diagram :
Hi Dipesh,
you should undestand the followin: BGP defines how the traffic will be routed ingress and outgress of you network.
The BGP information that you're sending TO your ISP defines how the incoming traffic will be routed to your network.
The BGP information that you're gettin FROM your ISP defines how the outgoing traffic will be routed from you network.
it should  look like this:
TATA CE router :
router bgp 65500
bgp log-neighbor-changes
neighbor 172.1.25.189 remote-as 4755
address-family ipv4
  neighbor 172.1.25.189 activate
  neighbor 172.1.25.189 allowas-in
  neighbor 172.1.25.189  route-map TATA-IN in
route-map TATA-IN permit 10
match ip address 1
set local-preference 150
route-map TATA-IN permit 20
match ip address 2
set local-preference 50
Airtel CE router :
router bgp 65500
neighbor 22.1.25.189 remote-as 7777
address-family ipv4
neighbor 22.1.25.189 activate
neighbor 22.1.25.189 allowas-in
neighbor 22.1.25.189 route-map AIRTEL-IN in
route-map AIRTEL-IN  permit 10
match ip address 1
route-map AIRTEL-IN permit 20
match ip address 2
21 Replies 21
what do you mean under "iBGP Load Sharing"?
loadsharing of traffic between 10.10.10.1 and devices 10.10.10.2 and 10.10.10.3?
loadsharing of outgoing traffic from you AS?
loadsharing of incoming traffic to your AS?
Dear Konstantin,
We have two MPLS links across the 30 locations across india. I have shown example of one location. I want to do a load sharing for all outgoing traffic from CORE switch (L3 Switch) between two MPLS links as shown in diagram.
Other locations have also the same scenario but the As no is different as each location.
As I understand :
- My TATA CE router is doing eBGP peering with TATA PE router
- My AIRTEL CE router is doing eBGP peering with AIRTEL PE router
- My CORE switch will do iBGP peering with TATA And AIRTEL CE routers and vice a versa.
- TATA CE Router will do iBGP peering with AIRTEL CE router.
- I will advertise all the Network segments from CORE switch.
Now How I will load share this traffic between these two MPLS links so that my both links will be utilized at the same time and when one link will goes down the other link will get full load.
I was afraid you asking for loadsharing for incoming traffic also .
in short: you can loadsharing outgoing traffic with help of iBGP, you need just to activate under "router bgp ..." the command "maximum-paths ibgp <..>"  'm not sure which hardware and/or IOS releases are support it, just test it) on your core switch. Make sure all atributes are the same! But, I'm not sure how will it work in case of different upstream AS (you get different AS-PATH attribute).
loadsharing for Incoming traffic is possible only on base of subnets, ie. you'rer announcing one subnets over AS1 and second over AS2 (of course don't forget the failover)
Dear Konstantin,
Can you show me the sample configuraton?
Hi Dipesh,
Try below
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml#conf5
routing traffic based on as-path access-list. Good to know.
Mahesh
sure:
see this link t's a little bit old, without this new feature, but explains good the background)
this links is explain this new feature "maximum-paths ibgp":
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/configuration/15-0s/irg-multi-load.html
I was think about a load sharing with 2 separate ISP and I'm quite sure  it's not really possible . I used some times ago a following method to sharing a OUTGOING traffic ncoming traffic is other story) between different ISP, it takes a little bit manual work, but worked pretty good. I assume you will utilized the links to your ISP 50/50:
1. with help of some traffic accountig (Netflow) you should "split" all public Internat prefixes into 2 parts, e.g. 1.0.0.0/8 - 171.255.255.255/8 is first part, the rest is the second part, you should calculate how much traffic will be send to subnets from first part and how much to the second part, and moving the "splitting" you're trying to reach the 50/50 ratio
2. then you create a prefix list for both of those parts, let say PART1 and PART2
3. you configure your BGP sessions with incoming route-map and assign thew local-preference like that:
- prefix PART1 on 10.10.10.2 gets local-prefierence150, prefix PART2 on 10.10.10.2 gets  110
- prefix PART1 on 10.10.10.3 gets local-prefierence110, prefix PART2 on 10.10.10.3 gets  150
so you will have in you BGP table all prefixes with two different local-preferences, and outgoing traffic will be sent to the "best" next-hop. Times to time it will be necessary to update the prefis lists in order to keep the ratio near to 50/50
incoming traffic can't be really load-sharing.
Dear All,
I had tried to configure accordingly. But iBGP is not working I am not getting routes from remote location in my CORE L3 switch.
Configuration :
Note IP address shown in Diagram I have changed : 10.2.1.0/24 is replaced by 192.168.150.0/24
Location 1 with AS no 65500: TATA CE router :
router bgp 65500
neighbor 172.1.25.189 remote-as 8888
neighbor 192.168.150.100 remote-as 65500
address-family ipv4
neighbor 192.168.150.100 activate
no auto-summary
no synchronization
exit-address-family
sh IP route  Output :
sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
B 192.168.149.0/24 [200/0] via 192.168.150.100, 00:00:18
B 192.168.148.0/24 [200/0] via 192.168.150.100, 00:00:18
C 192.168.150.0/24 is directly connected, FastEthernet0/0
B 192.168.147.0/24 [200/0] via 192.168.150.100, 00:00:18
172.1.0.0/30 is subnetted, 2 subnets
C 172.1.25.188 is directly connected, Serial1/1
B 172.1.41.28 [20/0] via 172.1.25.189, 00:01:14
B 192.168.11.0/24 [20/0] via 172.1.25.189, 00:01:14
22.0.0.0/30 is subnetted, 2 subnets
B 22.1.41.28 [200/0] via 192.168.150.240, 00:00:21
B 22.1.25.188 [200/0] via 192.168.150.240, 00:00:21
B 192.168.4.0/24 [200/0] via 192.168.150.240, 00:00:21
B 192.168.5.0/24 [200/0] via 192.168.150.240, 00:00:21
B 192.168.3.0/24 [20/0] via 172.1.25.189, 00:01:17
Location 1 with AS no 65500: Airtel CE router :
router bgp 65500
address-family ipv4
no auto-summary
no synchronization
exit-address-family
sh ip route
B 192.168.149.0/24 [200/0] via 192.168.150.100, 00:01:22
B 192.168.148.0/24 [200/0] via 192.168.150.100, 00:01:22
B 192.168.147.0/24 [200/0] via 192.168.150.100, 00:01:22
B 172.1.25.188 [20/0] via 22.1.25.189, 00:01:22
B 172.1.41.28 [20/0] via 22.1.25.189, 00:01:22
B 192.168.11.0/24 [20/0] via 22.1.25.189, 00:01:22
B 22.1.41.28 [20/0] via 22.1.25.189, 00:01:25
C 22.1.25.188 is directly connected, Serial1/1
B 192.168.4.0/24 [20/0] via 22.1.25.189, 00:01:25
B 192.168.5.0/24 [20/0] via 22.1.25.189, 00:01:25
B 192.168.3.0/24 [20/0] via 22.1.25.189, 00:01:26
Location 1 with AS no 65500: CORE  SWITCH:
router bgp 65500
no synchronization
network 192.168.147.0
network 192.168.148.0
network 192.168.149.0
network 192.168.150.0
neighbor 192.168.150.240 remote-as 65500
neighbor 192.168.150.250 remote-as 65500
no auto-summary
sh IP ROUTE Output
(Configuration is same at remote location with AS no 65501 and segmetns 192.168.3 - 5.0/24 and 192.168.11.0/24)
here I am not getting routes from the TATA CE and AIRTEL CE.
Can you help what is the reason. I f i am wrong somewhere in configuration pls suggest.
ip route
C 192.168.149.0/24 is directly connected, Vlan4
C 192.168.148.0/24 is directly connected, Vlan3
C 192.168.150.0/24 is directly connected, Vlan2
C 192.168.147.0/24 is directly connected, Vlan5
Dear Experts,
Please suggest.
please give us "show ip bgp" and "show ip bgp summ" output on CORE switch.
Dear All,
Please find :
sh ip bgp
BGP table version is 5, local router ID is 192.168.150.100
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
* i22.1.25.188/30   22.1.25.189              0    100      0 2255 i
* i22.1.41.28/30    22.1.25.189              0    100      0 2255 i
* i172.1.25.188/30  172.1.25.189             0    100      0 4755 i
* i172.1.41.28/30   172.1.25.189             0    100      0 4755 i
* i192.168.3.0      22.1.25.189              0    100      0 2255 65501 i
* i                 172.1.25.189             0    100      0 4755 65501 i
* i192.168.4.0      22.1.25.189              0    100      0 2255 65501 i
* i192.168.5.0      22.1.25.189              0    100      0 2255 65501 i
* i192.168.11.0     22.1.25.189              0    100      0 2255 65501 i
*> 192.168.147.0    0.0.0.0                  0         32768 i
*> 192.168.148.0    0.0.0.0                  0         32768 i
*> 192.168.149.0    0.0.0.0                  0         32768 i
*> 192.168.150.0    0.0.0.0                  0         32768 i
sh ip bgp summary
BGP router identifier 192.168.150.100, local AS number 65500
BGP table version is 5, main routing table version 5
12 network entries using 1404 bytes of memory
16 path entries using 832 bytes of memory
6/1 BGP path/bestpath attribute entries using 744 bytes of memory
4 BGP AS-PATH entries using 96 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 3076 total bytes of memory
BGP activity 12/0 prefixes, 16/0 paths, scan interval 60 secs
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
192.168.150.240 4 65500       9       7        5    0    0 00:02:33        6
192.168.150.250 4 65500       9       7        5    0    0 00:02:49        6
ahh, I can see the problem, your CORE router doesn't have a route to the next-hop in BGP table. You can configure  the iBGP sessions with CORE router on your ISP-egde routers as followin:
  neighbor 192.168.150.100  next-hop-self
thus the next-hop will be set to a IP of ISP-edge router and CORE will wee this IP in itr routing-table and will place BGP information in the main routing table.
Do you use Loopback IP for  iBGP sessions? It's better to use Loopback, but you need to configure additional command on each iBGP router:
  neighbor   update-source
DearExperts,
Thanks . Now I can see the Route in CORE switch routing Table.
Now I want to do load sharing in such a way that for reaching specific sement there are two path TATA and AIRTEL from CORE switch.
I have configure CORE
router bgp 65500
no synchronization
maximum-paths ibgp 2
no auto-summary
sh ip bgp
BGP table version is 13, local router ID is 192.168.150.100
*>i22.1.25.188/30   192.168.150.240          0    100      0 2255 i
*>i22.1.41.28/30    192.168.150.240          0    100      0 2255 i
*>i172.1.25.188/30  192.168.150.250          0    100      0 4755 i
*>i172.1.41.28/30   192.168.150.250          0    100      0 4755 i
* i192.168.3.0      192.168.150.250          0    100      0 4755 65501 i
*>i                 192.168.150.240          0    100      0 2255 65501 i
* i192.168.4.0      192.168.150.250          0    100      0 4755 65501 i
* i192.168.5.0      192.168.150.250          0    100      0 4755 65501 i
* i192.168.11.0     192.168.150.250          0    100      0 4755 65501 i
sh ip bgp summary
BGP table version is 13, main routing table version 13
6/4 BGP path/bestpath attribute entries using 744 bytes of memory
192.168.150.240 4 65500      50      46       13    0    0 00:41:25        6
192.168.150.250 4 65500      48      46       13    0    0 00:41:24        6
sh ip bgp 192.168.11.0
BGP routing table entry for 192.168.11.0/24, version 13
Paths: (2 available, best #2, table Default-IP-Routing-Table)
Multipath: iBGP
  Not advertised to any peer
  4755 65501
    192.168.150.250 from 192.168.150.250 (192.168.150.250)
      Origin IGP, metric 0, localpref 100, valid, internal
  2255 65501
    192.168.150.240 from 192.168.150.240 (192.168.150.240)
      Origin IGP, metric 0, localpref 100, valid, internal, best
sh ip route
HAZ_CORE#sh ip route
B       172.1.25.188 [200/0] via 192.168.150.250, 00:42:17
B       172.1.41.28 [200/0] via 192.168.150.250, 00:42:17
B    192.168.11.0/24 [200/0] via 192.168.150.240, 00:38:28
B       22.1.41.28 [200/0] via 192.168.150.240, 00:39:59
B       22.1.25.188 [200/0] via 192.168.150.240, 00:39:59
B    192.168.4.0/24 [200/0] via 192.168.150.240, 00:38:31
B    192.168.5.0/24 [200/0] via 192.168.150.240, 00:38:31
B    192.168.3.0/24 [200/0] via 192.168.150.240, 00:38:33
traceroute 192.168.11.100
Tracing the route to 192.168.11.100
  1 192.168.150.240 160 msec 116 msec 48 msec
  2 22.1.25.189 [AS 2255] 68 msec 180 msec 108 msec
  3 22.2.2.2 236 msec 312 msec 292 msec
  4 22.1.41.30 [AS 2255] 376 msec 512 msec 272 msec
  5 192.168.11.100 [AS 65501] 392 msec 412 msec *
Loadsharing is not happening.
Please help.
as I said, I believe that iBGP loadsharing can work only if you connect to the same AS, because:
For multiple paths to the same destination to be considered as multipaths, the following criteria must be met:
  • All attributes must be the same. The attributes include weight, local  preference, autonomous system path (entire attribute and not just  length), origin code, Multi Exit Discriminator (MED), and Interior  Gateway Protocol (IGP) distance.
  • The next hop router for each multipath must be different.
Try instead to use the method I've described in my reply from  "09.11.2011 11:08" and split the destinations into 2 parts.
Dear Experts,
I have done so but I m not getting the result.
router bgp 65500
no synchronization
neighbor 192.168.150.240 route-map AIRTEL_Outgoing out
neighbor 192.168.150.250 route-map TATA_Outgoing out
no auto-summary
access-list 1 permit 192.168.147.0 0.0.0.255
access-list 1 permit 192.168.149.0 0.0.0.255
access-list 2 permit 192.168.150.0 0.0.0.255
access-list 2 permit 192.168.148.0 0.0.0.255
route-map TATA_Outgoing permit 10
match ip address 2
route-map TATA_Outgoing permit 20
route-map AIRTEL_Outgoing permit 10
match ip address 1
route-map AIRTEL_Outgoing permit 20
This will create two path one with LP 150 and other with LP 100. Same for Remote location with AS65501.
But teh Out Put is :
sh ip route
B       172.1.25.188 [200/0] via 192.168.150.250, 00:19:39
B       172.1.41.28 [200/0] via 192.168.150.250, 00:19:39
B    192.168.11.0/24 [200/0] via 192.168.150.240, 00:18:41
B       22.1.41.28 [200/0] via 192.168.150.240, 00:18:41
B       22.1.25.188 [200/0] via 192.168.150.240, 00:18:45
B    192.168.4.0/24 [200/0] via 192.168.150.240, 00:18:45
B    192.168.5.0/24 [200/0] via 192.168.150.240, 00:18:45
B    192.168.3.0/24 [200/0] via 192.168.150.240, 00:18:47
CORE#sh ip bgp
BGP table version is 17, local router ID is 192.168.150.100
OUTPUT of TATA CE router :
COnfig:
router bgp 65500
address-family ipv4
  no auto-summary
  no synchronization
exit-address-family
sh ip bgp
BGP table version is 13, local router ID is 192.168.150.250
r> 172.1.25.188/30  172.1.25.189             0             0 4755 i
*> 172.1.41.28/30   172.1.25.189                           0 4755 i
*> 192.168.3.0      172.1.25.189                           0 4755 65501 i
*> 192.168.4.0      172.1.25.189                           0 4755 65501 i
*> 192.168.5.0      172.1.25.189                           0 4755 65501 i
*> 192.168.11.0     172.1.25.189                           0 4755 65501 i
*>i192.168.147.0    192.168.150.100          0    100      0 i
*>i192.168.148.0    192.168.150.100          0    100      0 i
*>i192.168.149.0    192.168.150.100          0    100      0 i
r>i192.168.150.0    192.168.150.100          0    100      0 i
AIRTEL CE ROUTER OUTPUT
sh ip bgp
BGP table version is 13, local router ID is 192.168.150.240
r> 22.1.25.188/30   22.1.25.189              0             0 2255 i
*> 22.1.41.28/30    22.1.25.189                            0 2255 i
*> 192.168.3.0      22.1.25.189                            0 2255 65501 i
*> 192.168.4.0      22.1.25.189                            0 2255 65501 i
*> 192.168.5.0      22.1.25.189                            0 2255 65501 i
*> 192.168.11.0     22.1.25.189                            0 2255 65501 i
Also we can see rib failure.
Please help.
