Load sharing
I have an router with two serial interfaces that connected both of them to ISP,
I want load balancing and failover backup for my lan users
(NAT configuration also is an issue)
Silver
Re: Load sharing
some questions:
1- two serials to the same ISP?
2- have you got a routing protocol between your router and ISP?
Andrea
Re: Load sharing
hi Dear Andrew
1)actuallt every serial port connected to a VSAT modem and internet access
2)its based on static route
Silver
Re: Load sharing
Well, the best solution is maybe a simple load sharing, and not load balancing.
My idea is:
- divide your LAN in group A and group B (2 ip acl, first permit group A, second permit group B)
- try something like:
ip nat inside source list group_A int s0
ip nat inside source list group_B int s1
more infos:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_command_reference_chapter09186a008017d163.html#wp1079180
- then ip nat inside on your eth, and ip nat outside on both serials
the load sharing depends on group_A and group_B traffic ... Practice, but it works
Andrea
263
