Community Member
Localpref Impact with Equal Distance AS Paths
Hi all,
Given two equal distance AS Paths I would like to prefer one over the other. What is the best mechanism to implement this functionality? If one AS Path is shorter than another I want this path to be preferred regardless.
Thanks in advance,
Max
Re: Localpref Impact with Equal Distance AS Paths
Max,
The best way to do is to assign a HIGHER weight or higher local preference to the routes received from a particular router
BGP path selection is according to the below order.
1.Prefer the path with the highest WEIGHT
2.Prefer the path with the highest LOCAL_PREF
3.Prefer the path that was locally originated
4.Prefer the path with the shortest AS_PATH
5.Prefer the path with the lowest origin type
6.Prefer the path with the lowest
7.Prefer eBGP over iBGP paths
8.Prefer the path with the lowest IGP metric to the BGP next hop
9.Prefer the route that comes from the BGP router with the lowest router ID
10.Prefer the path that comes from the lowest neighbor address.
The Weight and the local pref attributes are checked first before checking the AS-Path. Hence by manipulating these attributes you can achieve what you want.
Check these links for config examples
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094309.shtml
http://www.cisco.com/en/US/tech/tk1330/tsd_technology_support_technical_reference_chapter09186a00807597c7.html#wp1020583
HTH, rate if it does
Narayan
Community Member
Narayan,
Okay - so to my original question, if I want to prefer one route over another only if the AS Paths are the same how would I do that? Setting a higher localpref will always superceed the AS Path length.
-Max
251
