10-19-2007 02:39 AM - edited 03-03-2019 07:14 PM
Sometimes we will forget we are logged into a router, how can I logout idled sessions?
10-19-2007 03:26 AM
hi
Try this
exec-timeout 0 10
regds
10-19-2007 05:32 AM
Edwin
While I agree that having an idle timeout is a good protection against having telnet sessions that someone forgot to logoff I believe that setting a timeout of 10 seconds is a bit stringent. Perhaps you are proposing a temporary change to clear the session and then go back to normal? But that does not work. Existing sessions are not impacted by changing the exec-timeout. I just tested it. I established a telnet, and then changed the exec-timeout of the vty. It has been idle for several minutes and has not been terminated by the short exec-timeout.
Andy
I believe that you should check out the command clear line vty and see if it does what you need.
Rick
