Loop from 7206 VXR
Can we give loop from 7206 VXR router ??
regds
Silver
Re: Loop from 7206 VXR
Nasheer
It depends on the interface you are using for the LOOP. So on VXR you can installed the DS3 card becasue it is having mid plane characterstics. Even you can get the loop if you are using STM card o particular KLM you can ask the provider to give you the LOOP. If you are using ethernet interface then loop is not possibl. You can ask the provider to perform the ethernet testing with the help of BERT meter and provide you all the details.
regards
shivlu
Silver
Is your issue has been resolved or not ?
regards
shivlu
116
