loopback test
I have 3600 router which is connected over E1 link to other router.
I want to give soft loop from router toward BERT meter, can it possible.
I hve done following things
config t> int Se0/1
then go to loopback command and execute , but BERT meter could not detect that loop , is there any other way to give loopback toward BERT side
-Vinod
1 REPLY
Re: loopback test
Try to give a hard plug loop towards the Bert meter by shorting pins 1-4 and 2-5
Then use the same connector on your module and see whether the controller detects the loop.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a008010059a.shtml#topic1
Narayan
464
