Loss of connectivity/ATM bundle
Hi all,
I have a problem with ATM that my service provider and we say that it shuold not be happening.
We have 8 international sites connected through the same carrier.
The network topology is about the same at each site, as are the router configs.
A couple of those places are experiencing the problem I´m trying to solve.
Even though we have at least two E1´s bundled in one ATM IMA group, when one of the E1´s goes down, we lose connectivity to that site until the controller is up again. It doesn´t matter wich controller it is. At the other sites, when one controller goes down, we don´t lose connectivity. The routers, configs and the carrier are the same for all sites. Even the routing is the same
Can someone point me in the right direction, please?
Thanks to all for your help.
Eduardo.
CISCO IOS: c3725-jk9s-mz.123-16.bin
ROUTER CONFIG:
controller E1 0/0
mode atm aim 1
controller E1 0/1
mode atm aim 1
interface ATM0/0
description GM2413 to Lucent ATM network ima-group 0 4/1
bandwidth 2048
no ip address
load-interval 30
scrambling-payload
ima-group 0
no atm ilmi-keepalive
no clns route-cache
interface ATM0/1
bandwidth 2048
no ip address
load-interval 30
scrambling-payload
ima-group 0
no clns route-cache
interface ATM0/IMA0
bandwidth 4096
no ip address
load-interval 30
ima differential-delay-maximum 200
no clns route-cache
interface ATM0/IMA0.1 point-to-point
description 2 E1s ref. NSR GM2413 to Lucent ATM network ima-group 0 4/1
bandwidth 4096
ip address 162.xx.yyy.zzz 255.255.255.252
pvc 6/150
Re: Loss of connectivity/ATM bundle
Can you post the output of 'show ima interface ATM0/IMA0 detail'
--Sundar
Sure. Thanks for your response:
ARGENTINA1B_AIRES#sh ima inter atm0/ima0 det
Interface ATM0/IMA0 is up
Group index is 23
Ne state is operational, failure status is noFailure
IMA Group Current Configuration:
Tx/Rx minimum required links 1/1
Maximum allowed diff delay is 200ms, Tx frame length 128
Ne Tx clock mode CTC, configured timing reference link ATM0/0
Test pattern procedure is disabled
Detailed group Information:
Ne IMA version in operation IMA Version 1.1
Fe IMA version in operation IMA Version 1.1
Tx/Rx Ima_id 0x21/0x1
Ne state operational Fe state operational
Ne symmetry symmetricOperation Fe symmetry symmetricOperation
Number of Tx/Rx configured links 2/2
Number of Tx/Rx active links 2/2
Ne clock mode ctc, Tx frame length 128
Fe clock mode ctc, Rx frame length 128
Tx/Rx timing reference link 0/0
Maximum observed DCB depth 4 cells, Maximum DCB depth 2 cells
Maximum observed diff delay 0ms, Maximum diff delay 0ms
Least delayed link 1, Most delayed link 0
GTSM last changed 00:00:13 CST Mon Mar 1 1993
IMA Group Total Counters (time elapsed 2176 seconds):
1267277 Tx cells, 1295170 Rx cells
24 Ne Failures, 13 Fe Failures, 434 Unavail Secs
Detailed IMA link Information:
Interface ATM0/0 is up
ifIndex 9, Group Index 23, link exists and is operational
Tx/Rx Lid 0/0
Ne Tx/Rx state active/active
Fe Tx/Rx state active/active
Ne Rx failure status is noFailure
Fe Rx failure status is noFailure
Tx/Rx test pattern 0x0/0xFF
IMA Link Counters
0 Ima Violations, 0 Oif Anomalies
102 Ne Severely Err Secs, 335 Fe Severely Err Secs
1 Ne Unavail Secs, 1 Fe Unavail Secs
2 Ne Tx Unusable Secs, 94 Ne Rx Unusable Secs
47 Fe Tx Unusable Secs, 336 Fe Rx Unusable Secs
0 Ne Tx Failures, 5 Ne Rx Failures
6 Fe Tx Failures, 290 Fe Rx Failures
68377 Tx stuff events, 68090 Rx stuff events
Interface ATM0/1 is up
ifIndex 14, Group Index 23, link exists and is operational
Tx/Rx Lid 1/1
IMA Link Counters
6980 Ne Severely Err Secs, 6982 Fe Severely Err Secs
0 Ne Tx Unusable Secs, 6973 Ne Rx Unusable Secs
6468 Fe Tx Unusable Secs, 6991 Fe Rx Unusable Secs
0 Ne Tx Failures, 3 Ne Rx Failures
7 Fe Tx Failures, 501 Fe Rx Failures
39842 Tx stuff events, 24357 Rx stuff events
Config looks OK.
How do you know both links didn't go down when you couldn't get to the device. There are errors on both ATM interfaces. What was the status of the PVC on the other end of the connection?
--Sundar
The site has another carrier and we had the oprtunity to connect through them while running a series of tests. The router log only shows that one link goes down, but not the other. The errors are due to an interface converter that will be replaced in a few days. The pvc on the other side is up. They do not see any problem as well.
The best way to troubleshoot this is to connect to the router via out-of-band connection, disable one ATM interface and run debugs. With no out-of-band access you would have go by what carrier tells you is the status of the 2nd link and mightn't be that helpful.
Troubleshoot IMA using the following document.
http://www.cisco.com/en/US/partner/tech/tk39/tk356/technologies_tech_note09186a0080093d52.shtml
Post any specific questions to the forum.
--Sundar
Thanks! I appreciate your help. As soon as we run some tests, I´ll keep you posted.
It seems that the problem was a misconfigured pvc
in our service provider network. The pvc min bw was configured for about 4MB, so when one E1 went down, the remaining bw (2MB) was not enough to support the pvc, so the pvc went down. Our ISP configured the min
bw to 1886800 and that did it.
Thanks for your interest and your comments.
Eduardo
292
